Interceptor
Interceptor
Hey guys i received my interceptor in the mail yesterday and decided to go and try it out today, i just plugged it into the obd2 port or w/e u call that thing, and no joke it came on the gauge, and i was getting ready to wire her up, well it worked first off, so i started to play with it, tryed out some scans on it, and i was driving around with it on and it looks fun, its not fully installed yet, because i need a pod to put it in, but i put it into my cup holder now just to play with it today, but anyways, i got a question, how can u use the shift light on it, and how come when i go to scna hp it tells me well over 400hp, haha, but besides them, im loving it, changed the thing to say ss edition, and all that, and the current things i have scanning are on top IAT2 temps, and bottom is Battery, and does this sound about right, at 86 degrees at 60mph, the car runs at about 125 degrees on the IAT2 and the battery runs at a 14.1 at idle, and with the radio turned off, and then when my radio turned on at about 13.6 or so, but when a bass note hit it gets to about 13
that all sounds right.
Your IAT2s will change depending on ambient temperature....and of course what you do with your right foot.
The shift light will only work if you put the data rate on 1. which is the fastest data aquisition speed.
your HP may be off due to incorrect altitude settings, check what you have inputted there.
there is also a HP multiplier setting, which should be set to 100%
so data rate put on 1 and the hp do wat? haha im a little retarted, i saw the altitude thingy, and i changed the hp setting or w/e that is, it was set to 100, so i set to like 230 since thats wat i think my car is probabaly at
