Interceptor... Help /:
Old Mar 30, 2012 | 05:51 PM
TStone's Avatar
Exclamation Interceptor... Help /:
Got it all wired up.. turns on and off fine.... but when it turns on, it just displays "Intake Air Temperature"..
Hit the right button and it doesn't switch the things, same with the left button.. Like it won't leave "Intake Air Temperature"..
It also isn't even reading the Intake air temperature.. like the only thing on the screen is the word "Intake air temperature".. and it's displaying that for the top and bottom reading..
I can't seem to get it off either of those..
I also set it to where it read boost, knock, iat1 and 2.. and other things.. so I know that's not the problem... anyone else got any ideas?
Another Update.... like it goes through all the stuff at the beginning, and as soon as it gets to the screen that is supposed to be reading stuff, if you want to do something, you have to click the buttons RIGHT AWAY.... like once it hits the screen that's supposed to be reading stuff, you can hit the two buttons and go to the menu, but you have to hit it AS SOON AS it gets on that screen.. if you wait even 5 seconds, and hit both buttons, nothing will happen......
I also tried it just hitting one button... As soon as it got to the last screen, I hit it right away, and it changed the reading to IAT2, which would be next, but it's still not reading my IAT2...
annnd I didn't know if I should put this in this section, General Cobalt section, Problems section, or electronics section... move if need be
Old Mar 30, 2012 | 05:56 PM
tanelk's Avatar
R u sure u connected everything right?
Old Mar 30, 2012 | 06:01 PM
TStone's Avatar
Obd2 to the OBD2... red power wire to fuse.... red jumper off...
Old Mar 30, 2012 | 06:06 PM
advise's Avatar
hold both buttons and got to set up and make sure you have more perameters selected then just ait1
Old Mar 30, 2012 | 06:10 PM
TStone's Avatar
didddd
Old Mar 30, 2012 | 06:14 PM
tanelk's Avatar
What about scan
Old Mar 30, 2012 | 06:16 PM
TStone's Avatar
What about scan
Like click scan? It goes straight to the screen displaying "Intake Air Temeprature" on the top and bottom, but not ACTUALLY reading them, and not letting me switch to another parameter
Old Mar 30, 2012 | 06:48 PM
tbellazzi's Avatar
Just curious if you just installed this or if this is an issue that recently developed?
Old Mar 30, 2012 | 06:53 PM
TStone's Avatar
just installed
Old Mar 30, 2012 | 08:18 PM
robd53's Avatar
I know my gauges would freeze and restart if I had selected parameters that weren't available for my car. Do you have any odd parameters towards the bottom of the setup list selected?
Old Mar 30, 2012 | 08:20 PM
TStone's Avatar
Nope. I only selected the ones I knew would work.. like boost, kr3, iat2, iat1
Old Mar 30, 2012 | 09:28 PM
tbellazzi's Avatar
I just ordered one of these...hope I don't hit the same issue! best of luck bro!
Old Mar 30, 2012 | 09:34 PM
Bluelightning's Avatar
Got Bewst?
Bad gauge? I got mine, hooked it up and it worked minty. Wierd.
Old Mar 30, 2012 | 09:37 PM
TStone's Avatar
I sure hope not.. lol .. damn itttt. this sucks
Old Mar 30, 2012 | 09:58 PM
TommyP's Avatar
AWD > FWD
I would guess defective gauge. If you have it set up properly it should work fine. There isn't much as far as wiring that you can screw up.
Old Mar 30, 2012 | 10:11 PM
TStone's Avatar
Damn it /: Well I E mailed Aeroforce.. i'll see what they say.
Old Mar 30, 2012 | 10:28 PM
Orange07ss's Avatar
I never took the red jumper off my guage...I don't have it hooked up to a source though (currently I just unplug it then plug it back in.) Correct me if I'm wrong, but the red jumper should still be there
Old Mar 30, 2012 | 10:30 PM
Got Bewst?
Jumper stays if you are not using a 12v source and is removed when using a 12v source. He's got it hooked up right.
Old Mar 30, 2012 | 10:35 PM
Orange07ss's Avatar
Gotcha, kind figured it was something like that, figured I'd throw it out there though.
FryLoch
May 11, 2012 09:48 PM
Edubs
Jun 18, 2011 01:41 PM
Nakaiya21
Dec 6, 2008 02:20 PM
SlowBalt_06
Jan 29, 2008 03:17 PM
