Interceptor help
Interceptor help
Okay just got done installing my interceptor and it won't turn on. I have the OBD plugged into the car and the gauge, the other plug in I have the red wire going to a switched power source and the other two are not needed (I think). I did take off the red "jumper". Any advice would be great guys, thanks.
The other two are for your Analog1 and Analog2 inputs. I sugest checking the voltage at your red wire plug. Then check for the proper groind on the OBDII plug. Not sure wich pin though. If thats all good try a diffrent interceptor. (Make sure the key is ON though)
any update on this? I just installed mine, removed the jumper, hookup power and it still wont power on. When i first plug it into the OBD II port it does power up, this is even without the jumper in...Should I be sending this back for a new unit?
