Intercooler pump malfunction cause reduced HP?
Can having a broke Intercooler pump mess with my horsepower? When I replace the pump do I need to unplug my battery to reset the ECM to see my power back to normal?
Yes because your IATs skyrocket and the car pulls timing.
No you dont have to mess with the battery. Just make sure to refill the system when you replace. |
Ok well I did the old hit the pump with a hammer deal should I see increased HP right away then?
It's functioning properly for the time being |
Also when the car pulls timing the screen reads "engine power reduced" correct?
You probably have more of a problem than the pump being dead. Check the codes.
There are no codes
Originally Posted by tonyfabo
(Post 6901352)
There are no codes
That happened a whole ago I hit 120 I'm guessing my iats got too high an it killed my car before I blew
If the pump is dead it reduces timing without a code? |
(Post 6901363)
Boom! Sweet
Ive hit 210 degree IATs before and that was with a working pump.:lol:
I was talking 120 mph I don't have a monitoring gauge
I know you were.
(Post 6901337)
Changing the pump isn't just gonna bring your from say 180 back to 205hp for example. It's only gonna pull timing if it gets really hot.
U need to change ur pump u wont gain hp u just wont loss hp due to timing being pulled.
buy a new one. /end thread
