Intercooler pump replaced and still not working
Old Aug 1, 2011 | 01:21 AM
thedude411's Avatar
Well my intercooler pump went **** up so I ordered a new one. Car has 100k on it so it did it's time. Well I put the new one in and the new one won't work either. So I tried to check the fuse but I can't really find it. I'm thinking its the one labeled IP ING and is a 20a fuse? That fuse is fine and the pumps plug seems to be properly plugged in. I cannot find where it's grounded to but I read on here it's near the alternator...
Any idea what could be causing the new pump to not work? Also is the fuse labelled IP ING for the intercooler pump?? I want to make sure it's actually the pump that's faulty before I phone the vendor I bought it from and try to get them to exchange it.
Old Aug 1, 2011 | 01:25 AM
Chevycobaltss3's Avatar
Ip ign stands for ip ignition so thats bot the fuse..... Make sure its fully connected and go from there. How do u know its not working? Put 12v to it and ground it to see if it turns and ect if so pump is good then let the car run and check voltage from the hot wire in the harness to the pump and also the checck the ohms in both ground and hot wires when car is off
Old Aug 1, 2011 | 02:15 AM
thedude411's Avatar
Kk I'll try that tomorrow. Any idea what fuse is for the intercooler pump?
Old Aug 1, 2011 | 11:48 AM
06blackbalt's Avatar
it should be a 15a fuse it tells you were it is under your fuse box cover
Old Aug 1, 2011 | 01:15 PM
thedude411's Avatar
I pulled and checked every fuse under the hood. Everything looks good on that end. I still don't see intercooler pump or anything that would describe the intercooler pump on the fuse box cover tho. I've looked like 5 times now I must be going blind if it's listed on there. I'm going to try the first suggestion tomorrow after work. Hopefully that sorts my problems out
Old Aug 1, 2011 | 01:48 PM
ben_gary's Avatar
get a wire tester. then check if any power where it plugs into the IC pump
Old Aug 1, 2011 | 01:55 PM
1LowLS's Avatar
the fuse will say aftercooler i believe
Sharkey's Avatar
iirc its marked "aftercooler". also there is a relay for it, you can try swapping that with another relay to see if it works. keep in mind the car has to be running.
Old Aug 1, 2011 | 02:27 PM
Boosted05's Avatar
They key only has to be in the ON position for they pump to come on. That's what I do at at strip, flip my key on and let it cool down after runs, and that's how ZZP blew my system of air.
Old Aug 1, 2011 | 06:58 PM
thedude411's Avatar
I connected it to the battery and a ground and the pump worked. So I'm kind of happy that I don't need to return it. I swapped the relays with another source and the aftercooler fuse is still intact. I guess i now need to pick up a voltmeter to see if it's getting power..
Old Aug 1, 2011 | 07:43 PM
Special's Avatar
My guess would be that it's not getting power. Turn the key on, and use a volt meter.
Old Aug 1, 2011 | 08:23 PM
Sharkey's Avatar
interesting. my pump doesnt actually come on till the engine is running. must be different tuning.
Old Aug 1, 2011 | 08:36 PM
thedude411's Avatar
That's actually something u can set up when u get tuned through hp tuners or trifecta. it's a great option if u go to the track a lot.
SmitBag
Sep 7, 2016 08:05 AM
vjoel2011
Oct 2, 2015 12:11 PM
Cptnslo
Sep 24, 2015 09:32 AM
bucks121
Sep 12, 2015 07:39 PM
shawnsseries
Sep 10, 2015 08:29 PM
