intercooler pump replacement
Old Jul 15, 2008 | 12:16 AM
brandondrecksage's Avatar
I got my lightning/terminator intercooler pump. Are the electrical connections the same as the stock pump, i haven't been able to take a look yet and searching has found nothing. Figured someone who has done this would know.
ps...i find it ironic that the thing to fix my car came in a ford racing box.
Old Jul 15, 2008 | 12:18 AM
rrutter81's Avatar
hmmm im actually interested in this.... can u tell me how it helps if you have hptuners or interceptor?
thx
Old Jul 15, 2008 | 12:20 AM
ColeJJones's Avatar
Bannned
yea, you got a a picture of it and what is the flow rate compared to stock?
Old Jul 15, 2008 | 05:14 AM
hungryhip-ccp's Avatar
x2 subsribed for later viewing....
Old Jul 15, 2008 | 07:58 AM
thx
Not sure, I searched for a replacement and this is what people told me to get.
Ijust knew my stock pump was dead because i was seeing cruising iat2s of 140-150 and wot iat2s of 190.
Not suure, I think it was comparable to stock, i will take pics tonight when i get home from work.
Old Jul 15, 2008 | 08:01 AM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
I mean, theres gonna be a + and a -.
Old Jul 15, 2008 | 08:02 AM
BOOSSTED 06's Avatar
IM 99% sure its the same exact pump correct me if Im wrong
Old Jul 15, 2008 | 08:22 AM
lewisb13's Avatar
I mean I dont think its the exact same model and everything...hang on let me get the part #....
NM I cant find the damn thing!
Old Jul 15, 2008 | 08:24 AM
yeah i cant get the part numbers either, hahaha
Old Jul 15, 2008 | 05:47 PM
this is the part number
Manufacturer: Ford Racing (#M-8501-L54)
Old Jul 15, 2008 | 06:01 PM
rrutter81's Avatar
let me know what your IATs drop to under WOT
Old Jul 15, 2008 | 06:06 PM
190 wow that musta been scary like
does anyone know of a pump that is a upgrade??? not just replacement i saw it on here before but cant find the thread anymore
Last edited by hungryhip-ccp; Jul 15, 2008 at 06:06 PM. Reason: Automerged Doublepost
Old Jul 15, 2008 | 06:36 PM
I don't know what my iat2s were to begin with, bought a interceptor gauge, went drag racing, saw 190 and came on here to ask if that was normal. Then I searched to figure out if the pump was working. I'll let you guys know what it goes down to since the track is open tomorrow.
I read in a thread its just a replacement.
Old Jul 16, 2008 | 11:07 AM
anyone have any idea on how to get the clamps off the hoses that go in and out of the pump?
Old Jul 16, 2008 | 11:24 AM
mike25's Avatar
if its what i think they may be they squeeze off...there should be metal prongs on the top or the clamp spaced out a litle bit...squeeze them together....if its even what im thinking it is
Old Jul 16, 2008 | 11:26 AM
yeah they squeez off, but the are glue in place on the hose too so you cant just easily squeeze and slide, you have to squeeze the clamp and yank the hose off at the same time, take some elbow grease
Old Jul 16, 2008 | 11:28 AM
ColeJJones's Avatar
Bannned
so where the **** are the pictures
Old Jul 16, 2008 | 11:34 AM
HidKidSS's Avatar
what clamps are you talking about an why in the world would it be glued?
i changed mine a few months back.
all you have to do is get a good grip in the hose an pull.
the stock innercooler pump an the inlet an outlet where the hose are connect.
they have a little lip that is a bitch to pull off
but theres no glue an no clamps...
well on mine there were no clamps i dont know about the newer model over 05
i will try an find my old pump if i didnt throw it away to show you the lip that you have to try an pull the hose over
Old Jul 16, 2008 | 11:49 AM
mike25's Avatar
its gm...they used thos cheap squeeze clamps...its a shitty excuse for a clamp...just a little metal ring...squeeze the ends together and it comes off...
Old Jul 16, 2008 | 12:13 PM
I had mine off many times, mine had spiral clamps with a little glu to keep them in place on the hose. Had to squeeze the clamp then tug on the hose that was on mine. Same style clamp that was on the other side of the hose that went to the stock exchanger. Yours could be diff, just telling you how mine were. No need to get all irrate. My pump had a lip too but the clamps were on there as well
right, they had a dab a glue on mine that kept the clamp in that spot though, you couldnt just squeeze and twist like you can with the clamps on the vacuum hoses, was a bitch
Last edited by BOOSSTED 06; Jul 16, 2008 at 12:13 PM. Reason: Automerged Doublepost
Old Jul 16, 2008 | 12:20 PM
i can squeeze them all the way, but can't rotate or pull off. I'm taking a break, my hands hurt from holding the clamps open.
Old Jul 16, 2008 | 12:22 PM
read my post, they are glue in place, you have to squeeze and pull the hose not the clamp
Old Jul 16, 2008 | 12:41 PM
Tazmanian_Dvl's Avatar
subscribed...
Old Jul 16, 2008 | 05:58 PM
cobaltBlackss's Avatar
More details...
Old Jul 16, 2008 | 07:05 PM
I bent the clamps squeezing them together...so i cut the hoses right after the clamps. There was enough slack to put the hoses over the new pump. Filled the coolant back up that was lost. My cruising iats were about 35 degrees above iat, does that sound correct?
