interior door handle problem
Old Oct 27, 2012 | 02:13 PM
stevenferris1's Avatar
so I searched and couldnt find much on this issue but yesterday i drove my car to work, and obviously when you start driving your doors automatically lock, well i was dumb and forgot so when i go to get out of the car i pulled the handle and felt a click and now my interior door handle has no tension at all
simply put my doors shut, and my interior door handle doesnt work, the exterior handle still has tension like it normally does but cant open it either, even when i lock or unlock the door. so im not quite sure what the issue is. and the big question is, is how am i going to fix this or get the door panel off if my door wont open :/
any advice?
Old Oct 27, 2012 | 02:17 PM
Gelladuga69's Avatar
Common problem.
Bang on the outside of your door with an open palm where the door mechanism would lock onto the chassis.
It'll eventually catch and you'll be able to open the door. THEN WD-40/Grease the **** out of it.
OR you could lock and unlock the door manually a bunch of times, not with the buttons, and it might catch that way as well.
Old Oct 27, 2012 | 02:35 PM
thanks! im going to go try this now haha
Old Oct 27, 2012 | 02:38 PM
wow. literally fixed in 15 seconds, i just manually pulled up and down on the interior door lock a couple times and bam it works, thanks again!
Old Oct 27, 2012 | 04:38 PM
No problem! Glad it worked for you.
Old Jan 11, 2014 | 11:44 AM
Pitbull2o08's Avatar
Having this problem. No tension on inside or outside of the drivers door. Any help?
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
patooyee
Oct 15, 2015 05:11 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
