Just got new stuff in,Need Help w/aeorforce
Old Apr 11, 2008 | 08:59 PM
kwest's Avatar
hey guys, i just got my aeroforce interceptor in today, and i have to say i was kinda disappointed. not only does it look cheap as hell, but its not what i was told i was getting. i ordered it through cobalt-addiction, which was supost to be the SS start up screen edition, and its not. so that was pretty irritating. but besides that, the instructions suck on this thing. so it comes with the plug for my computer, and then another harness with a red, white, and green wire. i know the red if for 12v power to start the gauge up only when the ignition is turned on, but what are the others?? and how do i set up the shift lights? any help is greatly appreciated. thanks guys
Old Apr 11, 2008 | 09:01 PM
beercan's Avatar
The green and white wires are analog inputs .. and just go to your shift light option and the left button will increase the number and use the right button to move over tothe next number
Old Apr 11, 2008 | 09:08 PM
stg2ss's Avatar
subscribed
Old Apr 11, 2008 | 09:13 PM
ssmokin's Avatar
you have to set it up! READ THE MANUAL! Its really not that hard. Hit both buttons and figure it out! hit the left button to scroll the menu and the right button to select. you can choose the start up display you want and set the shift light (set the annunciator) then choose RPM and set it to where you want the shift light to come on then choose "above"
Old Apr 11, 2008 | 09:24 PM
kwest's Avatar
oh so in the set up there is actually a SS startup option i have to pick? and what is the menu called where i set the shift light? i keep hitting the right button till i see it, then adjust it with which button?
So the green and white i wouldnt even use in my case then??
Old Apr 11, 2008 | 09:37 PM
ssmokin's Avatar
SHIFT LIGHT
when you first start up the guage, it should say "annunciator not set up" hit both buttons and scroll (by hitting left button) to "annunciator" then hit the right button to select. then scroll to RPM and select. an asterisk should pop up next to RPM. then scroll down to EXIT. the guage should then read out 5 numbers. hit the left button to increase the numbers and when you are satisfied with that number hit the right button to continue to the next number. example, if your redline is 6800 you may want to set it at 6600. i have a 7200 and mine is set at 7000. after you have adjusted all of you numbers, the gauge will read "above" "below" and EXIT. highlight ABOVE and hit the right button then exit. your shift light is now set up.
LOGO
enter the menu and scroll to and select LOGO. scroll to and select SS. then EXIT. THATS IT!
hope that helps!
Old Apr 11, 2008 | 09:41 PM
HidKidSS's Avatar
SHIFT LIGHT
LOGO
hope that helps!
wish i had u explain that **** 2 me i just found out how to work those stupid things but now heres another thing the new updated ones 2.4 frameware has a bulit in turbo/cool down timer
how do you turn it off lol
Old Apr 11, 2008 | 09:42 PM
ssmokin's Avatar
sorry dude..no idea!
Old Apr 11, 2008 | 09:43 PM
HidKidSS's Avatar
ughh gr8 lol =/ so im stuck with a sc car with a fckin turbo timer on it...POINTLESSS!!!!
Old Apr 11, 2008 | 09:48 PM
ssmokin's Avatar
well not really pointless. turbo timers are just for lazy people who dont wanna let their car cool down after a hard run before shutting it off.
Old Apr 11, 2008 | 10:41 PM
golden chicken's Avatar
if you go to www.aeroforcetech.com you can download the entire manual. i printed mine out. it makes life a lot easier than trying to use that dinky excuse for a manual that comes in the box.
Old Apr 11, 2008 | 10:47 PM
kwest's Avatar
SHIFT LIGHT
LOGO
hope that helps!
Wow thanks dude, helps out alot. im about to go outside and try it now. oh and on the green white and red wires, i just use the red wire for power and dont use the other two?
Old Apr 11, 2008 | 11:04 PM
ssmokin's Avatar
nope. just the red. BTW. do you see a little red thing plugged in the back of your gauge?
p.s. are you near mount belvieu?
Old Apr 11, 2008 | 11:31 PM
kwest's Avatar
yes i see the red thing and im about 30 minutes away.
Old Apr 11, 2008 | 11:33 PM
ssmokin's Avatar
pull that red thing out! or it wont work properly. That is for the ion redlines. dont know why, just do it! it says it in the manual
Old Apr 12, 2008 | 12:06 AM
kwest's Avatar
Hey what is the annunctiator? and what do i go to to set up the shift light?
and i ran the red power to a 12v for power...how do i get the gauge to come on as soon as i turn the key on with my other gauges?
Old Apr 12, 2008 | 12:07 AM
ssmokin's Avatar
annunciator is the shift light...well, its both led lights and you can set them to come on for multiple parameters. didnt you read my above post? LOL i thought i explained it! lol
Old Apr 12, 2008 | 12:14 AM
kwest's Avatar
oh yea yea yea yea...haha sorry i forgot. oh and what about getting it to turn on as soon as the key is turned on?
Old Apr 12, 2008 | 12:20 AM
ssmokin's Avatar
what the gauge? where did you connect the red wire to?
Old Apr 12, 2008 | 12:21 AM
KillerBee's Avatar
Here is a link to the online manual
http://www.aeroforcetech.com/files/I..._version_4.pdf
Old Apr 12, 2008 | 12:26 AM
kwest's Avatar
I have a add a fuse that i ran through the firewall and up to my fuse box. and when i turn my car on i still have to hold the two buttons down to turn the gauge on
Old Apr 12, 2008 | 12:28 AM
ssmokin's Avatar
what fuse did you add to?
Old Apr 12, 2008 | 12:31 AM
KillerBee's Avatar
I ran mine to the wiper fuse and it comes on when the accesories come on no problem
Old Apr 12, 2008 | 12:33 AM
kwest's Avatar
thanks a ton, that has alot of good info!!
yea, i ran mine on the same power wire that i have my afr gauge ran to, and my afr gauge comes on when i turn the key on but the aeroforce doesnt...hmm i duno i guess i did something wrong but i will have to wait till tomorrow when i have daylight
Old Apr 12, 2008 | 12:35 AM
ssmokin's Avatar
did you pull out that red thing from the back of the gauge?
