just put my header on!
ok so i just installed my cti race header with the DP into the stock catback and now the car srsly runs like ****, its bogging and hesitating and throwing the cat code. is the cat code making it run like ****? or does the computer have to learn theres a new exhaust and relearn itself. or do i have to get it tuned out?
any input would be great ty
yeah you going to need a tune. I have the same exact header/downpipe and my car lags until like 4500rpm cuz i have no back pressure at all. I need retuned plus for my meth again. tune is the best opition.
You shouldn't be having any problems. You car is throwing a code because of the cat its a P420 code. Even throwing that code wouldn't hurt the car a lot of people run with it on. I had GM stage 2 and Ran my ZZP Midlength with a HighFlow for about 10,000 miles. My car ran great, I threw a code every now and then but i just cleared it with my interceptor. Your car shouldn't be bogging down you might wanna check what code and go from there.
you shouldn't be having any problems. You car is throwing a code because of the cat its a p420 code. Even throwing that code wouldn't hurt the car a lot of people run with it on. I had gm stage 2 and ran my zzp midlength with a highflow for about 10,000 miles. My car ran great, i threw a code every now and then but i just cleared it with my interceptor. Your car shouldn't be bogging down you might wanna check what code and go from there.
This header will not cause your car to lag till 4500rpms. There must be something else wrong.
i never had a problem with the car and as soon as i put the header in, all these codes came up wtf do i dooo rahhh
Make sure you didn't unplug any sensors or damage any thing when you were putting the header on. I'm not sure what the problems is something is not right. You shouldn't be having any of these problems after just putting a header and DP on.
When i swapped the engine i shorted out a ground cable which gave me like 10 different codes but yeah thats a totally different situation.
You're right. An effed up MAF circuit will make the car go into SD mode. The cel will not. It depends on why the CEL is on, but just because it is on doesn't mean your car will run any differently. For example, an insufficient catalyst code will not alter your car's performance, but a bad MAF will.
