Kaboom!!!!!!!
Old Nov 12, 2006 | 12:36 AM
cobaltBlackss's Avatar
Kaboom!!!!!!!
Five million points goes to the person who can guess what happened to my car while on the dyno!! If you guessed putting a hole in my number four piston you guessed right. My dipstick popped off and sprayed oil everywhere, then white smoke started filling the room. We took out the spark plugs and the #4 was dissentigrated. Maybe if my car suddenly becomes stock the dealership will fix it.
Old Nov 12, 2006 | 12:37 AM
Scythe_Snake's Avatar
Shoot bro, tough luck. i hope you get it fixed.
Old Nov 12, 2006 | 12:39 AM
NinjaHampster's Avatar
lets all hope the magical stock fearies appear and help you out
Old Nov 12, 2006 | 12:40 AM
stotte20's Avatar
wow that succks ass
Old Nov 12, 2006 | 12:43 AM
M88ArRamadi's Avatar
ouch......been there....well I AM THERE!!
Old Nov 12, 2006 | 12:46 AM
Blown 4-banger's Avatar
Why would you even try to get those stock pieces of **** replaced!?!? I'd be ordering JE or Diamond pistons right now!
g5mike's Avatar
mines not quite as bad but i bent my valves putting in cams,sorry for your badluck
Old Nov 12, 2006 | 12:47 AM
g5mike's Avatar
hopefully that piston didnt drop to far and screw the engine
Old Nov 12, 2006 | 12:49 AM
I will, but just in case they have to replace anything else I won't have to pay for it.
Old Nov 12, 2006 | 12:50 AM
Is anyone on here selling an m62?
StreetDreamz's Avatar
Same piston that went on my motor.
Why did you **** your blower too?
Old Nov 12, 2006 | 12:51 AM
yes I've noticed the #4 seems to be the weak link
Old Nov 12, 2006 | 12:52 AM
Allshot's Avatar
Probably becasue he has it powder coated and it doesnt look stock. And it grinded down
no, but mine is obviously altered.
HViper's Avatar
With all those mods you think you would of known the pistons on are cars are the weakspot. We got forged crank and rods, but cast pistons. Kinda like make a golf driver with a CF shaft and a glass bulb for the head. Just doesnt make sense. Anyway man, that sux that you blew your motot, but for some reason I dont think GM will cover it under warranty. Gonna need more than a magic stock fairy on this one, but good luck with the rebuild.
Old Nov 12, 2006 | 01:02 AM
joedashow's Avatar
That's beautiful...
Old Nov 12, 2006 | 01:04 AM
Originally Posted by joedashow
That's beautiful...
x2
Old Nov 12, 2006 | 01:11 AM
rally's Avatar
I can gurantee GM will not warranty this. All they will do is pull your car in (literally) then hook up a Tech 2, read what happened, and tell you how much to fix it. (I've seen this done at work a lot)
But good luck with that!
Old Nov 12, 2006 | 01:13 AM
Allshot's Avatar
What is a tech 2? What does it tell the dealer
Is there a way to erase my cars memory W/ hp tuners?
Old Nov 12, 2006 | 01:23 AM
Ljavy17's Avatar
put back the stock tune. thats it. They cant tell wether you had another tune in it. Also how much did she put down before she blew up.
Old Nov 12, 2006 | 01:28 AM
Bad06SS's Avatar
Sorry to hear. Definetely go forged this time. I'm curious, what was your AFR? How much boost and timing were you seeing?
Old Nov 12, 2006 | 01:45 AM
x2! I can almost bet he doesn't have a wideband.
Old Nov 12, 2006 | 01:53 AM
bdwarr6's Avatar
i will say it now
the stock setup is pure ****
get plently of rtv seal, locktight some elbow grease and good parts **** this GM Junk they put in it
I turned my pistons into astrays exactly what they are suited for
