Keeping the supercharger cool...
I know there have been a few posts about water injections kits...
I have been tossing the idea of using water injection just to cool the s/c when running a smaller pulley.
Cryo2 looks like a good idea, but a little on the expensive side...
As it looks water injection doesn't do much for hp gains with what we have, but would it be a cost effective idea to keep the s/c cool?
Also, I am getting the parts together and i'm going to start making a icebox for the aftercooler, similar to Billetflow's, but the ice chamber will be separate...
easiest way ............... new hood. heat opening in the rear and a ram in the front . have the air come in at the front bumper alowing it to flow over the s/c and engine and letting that HOT air escape out by the winshield
useing W/E, there have people that have used it and found that there was very little cooling happening. best thing to do is get an ice box from Billetflow to cool the coolant after the intercooler
Swapping Tstats would be a good idea. There definetely is one. I'd bet it was 192*. You could probably get a 180* from Autozone. I'd try to find a 160* though, but I know most local parts places don't carry any that cool. But I run a 160* without any problems.
jmc, you should run water wetter or one of the similar brands.. the max i seen was someone say the charge temps went down 20 degrees after they put that in the aftercooler system
form what i've noticed.. the ecotec likes to run warm 180~ degrees... i'm not sure how it would perform with a 160 t-stat
Originally Posted by Jsamps07
A few people I know with SC on other car put Ice bags on them at the track, but for street wise, idk.
pclear's suggestion is a great one...one of the best ways to start is by getting a functional hood that will both pull cooler outside air in and extract the heat from the engine bay.
Fo Real, Yo
hrmm, some interesting idea's...Yea, the Eco wouldn't perform that well at 160 degrees I don't think, 180 degrees is fine, but cooler is better in some cases....I already have in the works of making a ice box simular to Billetflow's...
Really what my main concern is just trying to keep the temps of the supercharger down...
Originally Posted by Tofu
my temp on the gauge cluster was 213 F when I ran my 13.85 hehe. Definitely should have brought an ice bag.
Originally Posted by Brian MP5T
Reverse Cowl is like so much more effective, the vac draws heat out, rather than inflating the engine compartment with an ugly scoop, which basically reduces airflow throught the rad...
Fo Real, Yo
Fo Real, Yo
well this is the one that i will be getting
take a look at the whole car
The engine looks well done and the interior is great minus the "Stereo"
They should throw some light weight rims and some killer dirt tires on it, it's at the right height...
Nice overall.
The Stereo has got to go.. It's called a Rally Concept, Yet they forgot to keep true to the conviction of it being a rally concept.. What the **** is up with the Speedo? I hope they aren't all like that.
Nice overall.
Nice overall.
the speedo? you mean the gauge cluster?
yes they are all like that, they are all center mounted, and dont even try to dis it before you drive some miles in it and then see how much easier it is than the front mounted gauge cluster.
Hmmm...
what he said^ im 6 foot 4 and when i drive my brother cobalt ss i cant read the RPM gauge
and cvenom no that setup would be uber inefficient unless a turbo was feeding air into that intercooler then into the tb
Dan
