knock retard help????
ok guys here my problem i'm knockin pretty good and cant figure out how to controll this...right now my current mods are gm stage 2 with a 2.85 pulley..aem intake...pacesetters armor coated header...magnaflow exhaust...copper plugs gapped at .40..i'm seein bout 5 degree's of knock..but i am seein the same knock with the stage 2 pulley...all the knock starts above 6k rpms...to redline....would meth help this? ohh yea always run 91 thats all thats really avaible besides 100 and no data logs sorry
wait a min..u said even with the stg2 pulley its the same?
yea when i dyno'd i was running a 2.8 and the same other stuff and was knockin bout 5 degree's i put down 242hp 224tq
yea...
yea...
Last edited by SlowBalt_06; Jun 24, 2008 at 09:37 PM. Reason: Automerged Doublepost
stage 2 timing is way too advanced. when i first got hptuners i was seeing 21* of timing up top. Even though i wasnt seeing any KR, i still pulled 2* of timing from the high octane table.
you said you use 91, but gm states 93 is required for stage 2. that on top of the advanced timing is probably giving you problems. you DEFINITELY dont want to run a 2.85 pulley. keep the stage 2 pulley, pull a couple deg out of your high octane table and see if that doesnt help
I was seeing about the same degree of knock on my stage 2 tune, so i had to retard the timing a bit. there has to be somewhere , in your town that sells 93 jus try it and see what happens.
my friend had alot of knock with his 2.8 and 42s... he should of been running 60s but he didnt listen to me
