KR at acceleration>??
Old Nov 3, 2009 | 06:11 PM
miked5426's Avatar
I keep getting KR after i hit the gas pedal following DFCO
even if i ease into the accleration, I still feel a slight jerk and KR can be anywhere from .5-2.0
Ive just replaced all my engine and trany mounts, LCA bushings, sway bar bushings..... but still dont see a difference.
my exhaust seems pretty tight, no loose parts underneith,
can anyone tel me what this FALSE knock could be>? its really annoying!
Old Nov 3, 2009 | 07:30 PM
HunterKiller89's Avatar
from all the LSJ tunes ive seen, throttle input changes will almost always result in KR, regardless of whether its throttle opening or closing. Its KR during constant throttle (such as WOT) that you want to avoid.
Old Nov 3, 2009 | 07:55 PM
miked5426's Avatar
so is there ANYTHING i can do? i dont remember it doing it 6 months ago or so....
Old Nov 6, 2009 | 10:37 PM
miked5426's Avatar
bump... for sum help
Old Nov 6, 2009 | 10:40 PM
1badBlueberrySC's Avatar
mounts can cause knock... but not piston slap knock.
I have seen it plenty of times on LSJs
Old Nov 6, 2009 | 10:43 PM
rnjmur's Avatar
My car always gets KR when I accelerate after DFCO. I think it has to do with going from DFCO timing advance to acceleration timing advance. If I go into WOT from DFCO I usually don't see KR, it is usually only when going into low to moderate acceleration.
Old Nov 6, 2009 | 10:59 PM
miked5426's Avatar
brand new mounts in last week. no difference at all. feels exactly the same.
yeah,,,, its after DFCO...but the harder i push gas the worse the knock is. I dont see it happening the way you are.
Old Nov 6, 2009 | 11:03 PM
it's the mounts... Solid motor mounts on my buddies LSJ netted in CELs.
What do you mean no difference at all?
Old Nov 6, 2009 | 11:04 PM
miked5426's Avatar
i got poly mounts from PROTHANE. as far as no difference, the knock and reaction i get as i hit the gas after DFCO, is the same. same feel, same amount of knock as i had with my factory mounts.
Old Nov 6, 2009 | 11:06 PM
Ah... well **** man iunno then. If you don't feel a loss in power then your fine! 2* is nothing
Old Nov 6, 2009 | 11:10 PM
miked5426's Avatar
yeah i dont feel a lose in power...just that jerk which feels rather uncomfortable.its like a second delay from the time i hit the gas. its like the throttle response is off with the pcm...like someone else mentioned.
i originally thought it was cuz of motor movement, but that issue has been thrown out.
