Le Riceburners OFFICIAL Build Thread
23 Attachment(s)
The one to end them all.
Figured 'potential mini build list' thread was no longer just potential. So I fixed that shit. Ok! As some of yall may know, I've been gathering parts for the last couple months to do a head + cams build and a valvetrain refresh. For those who are unfamiliar with my car, here's last years featured car of the month that I won, because my car is the best ever :razz: https://www.cobaltss.net/forums/feat...-fcotm-291116/ Minus this, that and the other thing, nothing has changed too drastically. Heres my current list of parts under the hood/trans Devilsown Progressive Meth Kit with 10 GPH Nozzle Custom Fabricated Front Mount Meth Tank 2.8” Pulley, Multiple Pulley System 60# Siemons Injectors ZZP 3" Intake WOTBOX ZZP Longtube Header/Catted Downpipe Combo ZZP Resonated 2.5" catback Ottp Stage 1 Heat exchanger GM Stage 2 Belt 574's Dual Pass Endplate ZZP Phelonic Manifold Spacer NGK 1 Step Colder Spark Plugs HPTuned JAMES RAKES TUNE OMG NOOOO GMPP Clutch Upgrade Kit ZZP Stage 1 Axles TTR Engine Mount Powell Race Parts Front Trans Mount LNF Rear Trans Mount LNF Shifter Linkage/Throwout Bearing TWM Short Shifter W/ Base Bushings, & Cable Clamp OK, so now here's the list of parts going on the car in the next couple of weeks :D LSJION ported/polished/decked/cleaned LSJ head ZZP Stage 2 Cams Performance Autowerks 80# Valvesprings ATI Super Damper (overdrive) ZZP Neutral Balance Shafts 2.7” pulley LSD Trans 80# injectors (for running the E85) New meth kit with more failsafes Machined front cover New timing set ARP Headbolts and timing chain guide bolts ZZP Stealth heat exhanger PC’d rims, cutoff shields and valve cover and strut brace New retrofits Luckily I’ve collected a good pile of piktarz for all to enjoy J Extra set of wheels I powdercoated mustang blue Attachment 27101 Said rims will be used with these 1” hub adapters for the hellafit Attachment 27102 Also powdercoated these cut off shields… Attachment 27103 for these! Attachment 27104 Attachment 27105 Attachment 27106 Attachment 27107 new wiring harness and ballasts Attachment 27108 Valve cover & new gasket Attachment 27109 Attachment 27110 head Attachment 27111 Attachment 27112 Attachment 27113 head gasket Attachment 27114 front cover gasket Attachment 27115 this badboy is from an 06 with 15,000 miles on it! Attachment 27116 Attachment 27117 some fluid, clutch pipe and throw out bearing for the refresh. Trans seems to row through the gears for what the levers are worth. CAN ANYONE TELL ME what to check out as far as the input shaft play etc are concerned to make sure this thing is good to go? Attachment 27118 Attachment 27119 timing stuff… all new guides, updated tensioner, cam gears, chain etc… Attachment 27120 new S/C bolts, thermostat, a seal for something I forget… fuel injector isolators Attachment 27121 the zzp neutral balance shafts. They are used but look great Attachment 27122 Attachment 27123 |
15 Attachment(s)
machined front cover…
Attachment 27086 for the OD ATI superdamper! Attachment 27087 here’s the performance autowerks 80# valvesprings Attachment 27088 a zzp magnetic drain plug :lol: Attachment 27089 new meth kit w/ goodies Attachment 27090 ARP headstuds Attachment 27091 ARP Timing chain guide bolts Attachment 27092 Ecotec Viton valve seals Attachment 27093 80# injectors and 2.7” OTTP pulley Attachment 27094 ZZP Stealth Heat Exchanger… we plan to tap a hole into it so I can still run an option b Attachment 27095 coppertech exhaust gasket and a v-band gasket that I never knew I needed for my longtube header :r: I was wondering where the leak was coming from Attachment 27096 Attachment 27097 I still am waiting for the cams to arrive. Then I’ll post a pic of those J And finally some stikarz!!! Note that zzp and ottp failed to provide stikerz Attachment 27098 crateenginedepot ftmfw Attachment 27099 So the plan is this: The car is in storage in my buddys garage. We have space there to work on our cars. We plan to lift the car up there to drop the cradle and go from there. Hoping to start next weekend, and be done a few weekends after that, and dyno tuning at Pwerks by march. I still need new valves. Perhaps supertech valves. Otherwise… that’s about it! Stay tuned and thanks for looking! Big thanks to everyone that has helped me so far too! :cssNET: Attachment 27100 |
And a giant chromed fartcan?
GL with everything man!
Yay! Now picts of the car in pieces lol pretty exciting man.
Riceburner for President!
Going all in ! Awesome stuff man !
i may have to see how this turns out:)
In on dis shiiit
In. Wish I had $$$$ to throw into my car, it'd be getting a turbo build lol
Should i be concerned about cam bearings?
Aww yeah
Im too excited. And people please, anyone whos been through this before please let me know if i seem to be missing anything to properly do this :) i think im all set minus lube oil and spark plugs
Your missing something called a Turbo.
Youre missing a Shut the fuck up!! :cussing:
:lol: |
(Post 7257012)
:lol: |
Those the moto ss or new dsp?
(Post 7257008)
Originally Posted by ECaulk
(Post 7257022)
Nvm, I see dat exhaust gasket lol
Spring retainers?
click
I was just thinking about those. God it never ends. And there i was a few months back thinking ahh itll only cost 2 grand lol
Looks good adam!
It does at up quite fast.
