lean?
heres my list:
gm stage 1
gm stage 2 pulley and belt
NGK BKR7E copper plugs .042 gap (one step colder)
K&N intake
TTR engine mount
i always run 93 from Shell, good stuff.
Problem:
checked the spark plugs and the ground prongs are all white as snow and even rainbow colored in a few spots. from my years as a nitrous junkie, i take that as a sign of very lean a/f and high cylinder temps. the car feels slow. it struggles to reach 15psi and at times wont go past 13psi. it lags on teh bottom end and just doesnt feel like the other stage 2 cobalts i have driven. i have been told by everyone here that the stage 1 ecu tune is the same as the stage 2 ecu tune. however i really have begun to doubt this.
Question:
Am i leaning out and about to detonate the **** out of this engine?
If so, what can i do to remedy this?
gm stage 1
K&N intake
TTR engine mount
Problem:
Question:
yes, but i was told by almost everyone that its the same tune, and i have seen many others on this forum do the same thing, even with smaller pulleys.
i dont have access to a wideband... i wish i did
stage is a tune to compensate for the larger fuel injectors not the smaller pulley....Stage 2 tune compensates for the pulley and the injectors so idk where you got your info from but theres a reason why your lean...sorry to hear though bro
it is the same tune.
GM uses the same tune for stage 1, 2 and 3... but 3 you get to switch to a higher octane map as an additional option.
i'm not sure what year your car is, but the tune for 2007 is really rich... so i don't know what your problem is. if stage 2 is all you have on your car, take it in and get it fixed for free!
Stage 1 and Stage 2 have the exact same tune. There is no compensation for the larger pulley, thats what the PCM does. It calculates how much fuel is needed based on air intake. There is no programing required. And stage 1 comes with injectors, not stage 2.
Get a dyno run from a local dyno shop, will prolly cost around 50 bucks or so. They can hook up a wideband and let you know whats going on.
lol what? EEEEHHHHHH WRONG!
lol if you could read i did say stage 1 comes with the fuel injectors and stage 2 is the smaller pulley i just thought the tune was changed to compensate for either the injectors or both the pulley and the injectors
1) A light white with metal still visible along with the prong intergrity (still square) is a good sign.
2) Your motor will always run extremely hot...it is a two liter pushing close to 250 hp...what do you expect?
SO....the discoloration I would worry about...the slight white...not a big deal.
anyone wanna post their reflash part number from their stage 2 papers so i can see if its the same? ****** dealership wont do the stage 2 calibration unless i have the papers to prove i bought an actual stage 2 kit and i only have the papers for stage 1...
i would throw it on the dyno and W/B but there isnt a shop with a dyno within 100 miles of where i live.
im really kicking myself in the ass right now for being cheap.
geez... for the love of cobalts will everyone please stop bickering about injectors.
i need to find someone wiht hptuners. anyone in north east ohio / northwest pennsylvania with hptuners who knows what they are doing please contact me.
Hey man i would go back to the factory plug size see if that helps any it show you have air intake and stage 2 i mean if you had exhaust or what not i would go 1 step colder but go back to stock plugs cause it does not say anywhere you need to drope to a colder plug with stage 2 with only a intake and stage 2 i would stay with factory plugs
omfg, ok, people are confused.
most people think that GM stage 2 is a reflash, pulley, hub, injectors, & belt, but that's not true.
you have GM stage 1 which is the 42.5# injectors & a reflash
you have Stage 2, which is the Hub, pulley & belt
and you have GM stage 1 & 2 which is everything together.
People didn't want to type GM stage 1 & 2, so instead they called it stage 2.
Stage 2 is also known as the Stage 1 to 2 conversion. so you can see why people get confused.
i have a 05 cobalt ss 2.0l and it is all stock and runs really rich what can i do to make it leaner? add an air intake? and sorry to hear about the car running chttps://www.cobaltss.net/forums//images/smilies/cussing.gif
rappier
rappier
Last edited by 05clutch; May 10, 2007 at 02:05 AM. Reason: wanted to throw in another line
Here.
Quoted Directly from Crate Engine Depot
STAGE 1
STAGE 2
STAGE 1 To 2 CONVERSION
can we stop making things up please?
STAGE 1
17801947 Stage 1 Performance Upgrade Kit, Cobalt SS/ION Redline.
For 05-07 Saturn Ion Redline and Cheverolet Cobalt SS only. This kit enhances engine performance to 230 hp (up from stock 205 hp). Includes high-flow injectors & specific performance engine calibration.
For 04-07 Saturn ION Redline And Chevrolet Cobalt SS only. This Kit enhances engine performance to 245 hp (up from stock 205 hp). Includes high-flow injectors, supercharger pulley, new special length supercharger belt & specific performance engine calibration.
Premium fuel required.
Kit includes:
1-12597994 Pulley 77.9mm
1-12597993 Belt
1-12597995 Injector kit
4-12597996 Injector (single service number) -------------------DEE DEE DEEEEEE
1-19158223 Wrench (MT2)
1-19158224 Wrench (MT2)
1-12599777 Hub
4-19157352 Bolts
1-12602431 Label
1-12597997 Instructions
Kit includes:
1-12597993 Belt
1-12599777 Hub
4-19157352 Bolts
1-12602431 Label
For 05-07 Saturn ION Redline And Chevrolet Cobalt SS with Stage 1 Performance upgrade kit already installed only.
This Kit converts your Stage 1 kit to Stage 2, increasing performance from 230 hp to 245 hp.
Includes supercharger pulley, new special length supercharger belt & specific performance engine calibration.
Well stage 1 comes with high flow injectors which causes more fuel use so no but if you get a cold air intake it will lean it out just a little bit do you have an exhaust cat back?
a clogged fuel filter could effect fuel delivery. It can be often overlooked. I had a fuel pump die on me due to a clogged filter. ever since, I change mine every year on all vehicles I have ever owned.
