Limp mode?
Old Dec 10, 2011 | 02:35 PM
TStone's Avatar
Limp mode?
Car started studdering, CEL came on, shut the car off, turned it back on, still studdering, then it died, and wouldn't start back up..... So I walked to work.. called my parents to have them get it towed while I was at work, step dad goes to my car to check it out and it fires right up and he drives it home.........? I'm home now on my break and the car starts up just perfect and runs fine....? Codes are......
P2101 Control Module Throttle Actuator Position Performance ECM, PCM
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance- ECM, PCM
P2119 Throttle Closed Position Performance ECM, PCM
Old Dec 10, 2011 | 05:49 PM
nhanson's Avatar
hmm...check TB plug connection
Old Dec 11, 2011 | 12:30 AM
ULWizSS's Avatar
Yeah your computer spazzed for a second a threw an few codes which sent it into limp mode. Oh the joy.
Would invest into hptuners or a interceptor. Its nice to clear issues and codes while you drive and be able to continue on.
Old Dec 14, 2011 | 05:12 PM
Proinmaster's Avatar
i had the same problem then it got frequently worse. eventually limp mode came on often and it was the throttle position sensor, 160 bucks for a new throttle body because the sensor can not be removed and havent had a problem sense
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
Dustonian131
Sep 23, 2015 08:03 PM
bucks121
Sep 12, 2015 07:39 PM
