little help with a custom stage for me..
Old May 23, 2007 | 06:15 PM
mikess06's Avatar
hey guys i just need a quick bit of info i want to just build my own staging kit so its suites me, first off i know i want like a 2.8 pulley what else do i need to complete the staging kit injectors, spark plugs, belts... like spec info i soon look for.... and maybe other things that would help the car run safe as possible thanks . thanks guys
Old May 23, 2007 | 06:31 PM
TheFordGuy's Avatar
and a really good tune
Old May 23, 2007 | 06:38 PM
XM15's Avatar
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/official-cooling-thread-59987/
^^^This couldn't hurt, either.
Old May 23, 2007 | 06:48 PM
DTM2188's Avatar
With the 2.8" pulley you'll need the GM Stage 2 belt, 60lb injectors, one step colder spark plugs, ZZP tensioner (maybe, depends on belt slip), and like said above, a tune. I would also recommend some sort of traction mods to help out with the added power.
Old May 23, 2007 | 06:58 PM
Area47's Avatar
Rent me! per hour
60lbs with the 2.8 is overkill.
Old May 23, 2007 | 07:17 PM
mikess06's Avatar
over kill? but will be safer than the 42's, i'm located in philly anyone know where i can get a good hp tune at thanks
Old May 23, 2007 | 07:19 PM
Area47's Avatar
Rent me! per hour
50's
if you don't plan on going lower then a 2.8
42.5's are on the edge, 50's would give a nice cushion
Old May 23, 2007 | 07:20 PM
Edubs's Avatar
Don't know about a tune in Philly, but I'd say go for 50's with the 2.8
You can use a 2.8 with aftermarket 42's up to 6500RPM. 60's, I agree, are overkill. A set of 50's would be just fine up to 7K and even higher. But with stock valvetrain and bottom end, you don't want to rev past 7K...
EDIT: Damn Area, you beat me to it, nice info though...You are rep'ed...
Old May 23, 2007 | 07:26 PM
mikess06's Avatar
hey where would i buy 50's from, what about if i plan on running nitrous like would i damage anything buy running 60's for a while until i get the nitrous
Old May 23, 2007 | 07:30 PM
Area47's Avatar
Rent me! per hour
im bored here at work, so im super poster!
zankies man.
depends on how cheap you want to be with them.
msd part number 2013
also, ford motorsports uses the same injectors as msd. just some food for thought. they just have to be high impedance
Old May 23, 2007 | 07:32 PM
mikess06's Avatar
haha yea me too i'm at work until like 12
so what about if i wanted to run nitrous 60's i should have, and can i hurt my engine by running 60's on it for a while until i get the nitrous wit the 2.8 pulley
Old May 23, 2007 | 07:33 PM
Edubs's Avatar
Eh, I'm going out for a drive in my car right now! Try this site...
http://www.cobaltperformanceparts.co...roducts_id=215
Old May 23, 2007 | 07:34 PM
mikess06's Avatar
hey dtm u got the tune time performance tune right, how is it
Old May 23, 2007 | 07:37 PM
TheFordGuy's Avatar
I thought the 50's don't work? Or are those ones in the link the actual ones that do?
Old May 23, 2007 | 07:38 PM
Area47's Avatar
Rent me! per hour
you can not run 21 degrees of timing in these cars on the bottle. so you have to find a way to control timing for when you are on and off bottle.
if you do a 2.8, intake, and full exhaust, you won't need a bottle
Old May 23, 2007 | 07:47 PM
mikess06's Avatar
hey buddy can u do me a favor i know some what about cars but i never really did understand what timing was totally, if u got time to i would love to read it
Old May 23, 2007 | 10:41 PM
Area47's Avatar
Rent me! per hour
i wouldn't say 50's are a complete waste. all boils down to what you are doing with the car. i have a goal in mind, and im pretty much there. then again, thats me
Old May 23, 2007 | 10:53 PM
mezzanno's Avatar
Originally Posted by denny
Guy's,
Lets clear something right now about this 60# Injectors are too much crap.
I have been tuning for quite a while....done stock....done 42# injectors and now 60# injectors.
IF you are boosting more then 15PSI you need 60# injectors to have a safe IDC (Injector duty cycle) enough said. I have the scans to prove this...
Example: my 2.6" pulley makes max of 19PSI with 60# and 21 degree of timing am sitting at 77% IDC.
The price difference is what between 42# and 60#? 60$ maybe BIG deal if that puts you in a safer enviroment why not. 2$ a day of saving....think about it.
50# injectors are a waste of time and so are 42# trust me on this....everybody here almost....are boosting over 15PSI!!
I cant say this enough people....this is not B.S this is real facts.
exactly what he said. Go with the 60's they are not overkill at all. Also they give you room to drop the pully in the future and can be tuned to have perfect drivability.
Old May 23, 2007 | 11:03 PM
Ron9919's Avatar
I live in MD and can tune your car just search up RON9919 and you will see all the rave about my tunes.
and def go with 60's screw the other injector sizes.
Old May 24, 2007 | 06:32 AM
DTM2188's Avatar
Yes, I have been using Tune Time Performance and I would recommend them to you, ask for Matt and tell him that Dan with the red Cobalt SS told you about them, he'll hook you up.
Old May 24, 2007 | 11:18 AM
Area47's Avatar
Rent me! per hour
or tell him bryan in KC sent you. he'll know what you're talkin about
Old May 24, 2007 | 11:36 AM
chevysalesman614's Avatar
traction mods are for chumps
Old May 24, 2007 | 11:38 AM
Area47's Avatar
Rent me! per hour
smoking them in second from a 30 punch makes tires angry
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 15, 2015 05:11 PM
grampss
Sep 27, 2015 08:51 PM
