lk9 intake mods for turbo swap
Old 09-10-2014, 12:19 PM
The Rookie24's Avatar
Ok i know this has beat to death but I've been looking everywhere for pics and info. What mods do i need to do to make the intake work for turbo swap
this what i was told but it hard to visually imagine it. does any one have pics of all the spots that need mods
The mounting holes need opened up from m6 to m8, one of the ports needs welded shut, a machined block needs welded onto the back for the stock map sensor, one of the front holes needs opened up and tapped for the brake booster line, and a small part needs to be ground off for the le5 tb to fit.
Also can i just use the saab throttle body ?
Old 09-10-2014, 12:52 PM
574's Avatar
You can use stock lsj tb with a spacer and more modification or use a 8 pin le5 throttle body.
Blue indicates areas that need plugged and the blue circle is a good spot to tap for brake booster or instead of plugging a hole drill it larger and tap for brake booster. Map sensor goes on back side, easy to see where.
https://www.google.com/url?sa=t&rct=...74649129,d.aWw
Old 09-10-2014, 05:00 PM
i have zzp pic of it whats the fitting at the top for ? and when you refer to blue circle you mean the shaded one or the the two non shaded ?
Old 09-10-2014, 05:17 PM
574's Avatar
The amount of vac sources you need will vary from person to person. the shaded blue circle is where it needs to be plugged the two non shaded circles are where you can tap for a brake booster
Old 09-11-2014, 10:41 AM
ok how about the underside of the manifold were the map needs to go does anyone have pics of that ?
Old 09-11-2014, 11:49 AM
Adiaz1ss's Avatar
Just drill a hole on the underside where it is flat. Make the hole just big enough for the sensor to fit snug and make sure its flat parallel to the manifold. You can use rtv gasket maker to make sure it doesnt fall out or anything.
Old 09-11-2014, 12:06 PM
ok i just don't have the intake still waiting for junk yard to take it out lol thats why i was having a hard time seeing what need to be done. one more question referring to the exhaust manifold if i get a zzp one can i jus grab a turbo off another car like a gti jus so i can get the car running and when i have more cash upgrade
Old 09-11-2014, 12:14 PM
Adiaz1ss's Avatar
You can get any turbo as long as it has a t3 4 bolt flange to bolt onto the zzp exhaust mani. Im not familiar with the gti turbos tho
Old 09-11-2014, 04:16 PM
South Central *********
JapEatr's Avatar
Old 09-11-2014, 06:52 PM
Great pics that block is added on correct ? How does it work u drill through the intake then weld that block on ? Can i jus drill a whole in the intake and mount the map sensor directly on the mani without that block ?
Old 09-11-2014, 06:54 PM
TStone's Avatar
block is added. yes drill holes and weld block on. and no you can't. the map won't seat correctly.
Old 09-11-2014, 07:53 PM
Does any one have the dimensions ?
Old 09-11-2014, 07:56 PM
TStone's Avatar
armcclure might. He can probably just make you a map pad for cheap....
Old 09-11-2014, 08:05 PM
JapEatr's Avatar
^^^ he did ours that i posted
Old 09-11-2014, 08:07 PM
TStone's Avatar
Yes. He is a mastermind.... sometimes
Old 09-11-2014, 08:18 PM
JapEatr's Avatar
ARMPerformance
Old 09-11-2014, 08:40 PM
574's Avatar
Originally Posted by JapEatr
ARMPerformance
This is who made\welded mine on also
Old 09-12-2014, 01:27 PM
ok ill look into that ok so i went the u pull it by and scraped up a good garret t25 oil and water cooled no shaft play off a 97 saab 900 2.0 I'm new to the whole it has a .48 ar and it has that square four bolt flange will that bolt up to zzp manifold or do i need a from t25 to to t3
ps the t25 is not permeant just to mock everything up and use the car till later in the future to upgrade the turbo
Old 09-12-2014, 01:29 PM
Spawne32's Avatar
what map sensor are you using japeatr?
Old 09-12-2014, 01:41 PM
JapEatr's Avatar
im going to run a 2.5bar tmap
Old 09-12-2014, 01:50 PM
Spawne32's Avatar
is that because you want the IAT measurement directly from the manifold? I was looking at the 2.5bar from DPE vettes. 2.5 bar map Was debating about just keeping the IAT in the maf to avoid calibration issues.
Old 09-12-2014, 02:09 PM
JapEatr's Avatar
yes i want IAT2, the IAT1 measurement is in the MAF
Old 09-12-2014, 05:22 PM
has anyone used a saab 900 garrett t25 turbo using a adapter going from a t3 to t25 will it fit ?
Old 09-12-2014, 05:51 PM
armcclure's Avatar
You're kidding, right?
Is is possible: yes
Is it going to flow worth a crap: no
There's a reason that very very few people on the lnf keep the stock manifold when upgrading the turbo. It just will not support the needed flow. And the Saab one is even worse than the lnf.
Anything you're going to be able to properly run on a full Saab setup is going to under perform a standard m62/e85 setup.
Old 09-12-2014, 06:12 PM
i don't plan on keeping the t25 its just temporary i only paid 30 bucks for it no shaft play good enough to get everything together i know its not gunna make insane horsepower i will get the bullseye when i have the cash and i don't plan on using a complete saab set up just the intake and the turbo for now and ill be getting zzp turbo header m simply asking with the adaptor that goes t3 to t25 will it clear
Quick Reply: lk9 intake mods for turbo swap
