Looking to get some goodies!
Old Jan 7, 2009 | 02:53 PM
redcobaltss's Avatar
Ok guys, I am looking to get some new things for the balt finally! Looking to get some bolt on stuff for the most performance. Heres what i have so far.
Stg 2
2.8
K&N intake
borla muffler
cat delete
Need ur opinions on which brands of the following i should get and why. Thanks in advance!
Header/downpipe combo (zzp?)
tranny mount
motor mount (ignalls?)
60's
heat exchanger (have 03 cobra one but looking at options)
some kind of tune( dont have enough for real dyno tune, looking at PCM's)
Old Jan 7, 2009 | 02:54 PM
Perfect.disguise's Avatar
Stage 2 but plan on running a 2.8 and 60's? Thats a waste of money.
Old Jan 7, 2009 | 02:58 PM
SilverSurferSS/SC's Avatar
Depends.....how much you looking to spend?
Old Jan 7, 2009 | 03:00 PM
1000 or less
can u explain
Last edited by redcobaltss; Jan 7, 2009 at 03:00 PM. Reason: Automerged Doublepost
Old Jan 7, 2009 | 03:12 PM
Originally Posted by redcobaltss
1000 or less
can u explain
Yes, GM Stage 2 is a 3.06 pulley belt,, 42.5lb injectors and a reflash. Why would you buy it then buy another pulley and injectors that you will have to get a tune for anyways. The only thing that you would be able to use from Stage 2 is the hub and belt. Basically buying everything twice. Note: Didn't realize you already have Stg 2.
Old Jan 7, 2009 | 03:19 PM
Its koo man i understand you now.
Old Jan 7, 2009 | 03:24 PM
CobaltSS 16's Avatar
get the ottp stage 1 kit.
Old Jan 7, 2009 | 03:29 PM
Can you point me in the right direction? Is it reliable?
*edit* i just saw the kit. It looks good but i have the 2.8 and stage 2 belt already
Old Jan 7, 2009 | 03:33 PM
http://www.ottperformance.com/p111/O...duct_info.html
Old Jan 7, 2009 | 03:48 PM
Thanks. What do u think about INTENSE and there PCM?
Old Jan 7, 2009 | 03:55 PM
I have heard bad things about all mail order reflashes, but from what I've read OTT is the best. It would be a good idea to get a local tune though.
Old Jan 7, 2009 | 04:00 PM
get the ott kit. you can get it without the pulley. OTT tune > Intense tune. OTT FTMFW.
Old Jan 7, 2009 | 04:19 PM
do u know if they just sell the pcm and maybe the injectors/harness by themselves
Old Jan 7, 2009 | 04:35 PM
tdipowered's Avatar
Im sure they can help you..just pm lsjwannabe and he will get you all squared away
Old Jan 7, 2009 | 04:50 PM
^^you beat me to it. Yes, contact lsjwannabe, and he will set you up good.
Old Jan 7, 2009 | 04:55 PM
As the others have said, pm lsjwannabe or fast98, they should be able to help you out. Very fair prices on their kits and I haven't heard a bad thing about their tunes yet!
Old Jan 7, 2009 | 05:02 PM
Pmed them. Now how about good but cheap exhaust??? header/downpipe?
Old Jan 7, 2009 | 05:26 PM
ZZP Stainless. Good product. Also heard good things about Clear Image Auto's header Dp.
Old Jan 7, 2009 | 05:45 PM
yea same here. just wanted to make sure. i think i might go with the ZZP set up.
Old Jan 7, 2009 | 05:50 PM
icemaid's Avatar
I have a zzp header w/dp for sale, not stainless, dp is 3" w/2.5 out to bolt to stock catback. was only on the car maybe 1000 k's
Old Jan 7, 2009 | 05:54 PM
really $?
Old Jan 7, 2009 | 06:34 PM
I like the ZZP set-up for sure.
Old Jan 7, 2009 | 08:56 PM
sounds good. i will order that tomorrow and order the stuff from OTTP!
Old Jan 7, 2009 | 09:03 PM
TurboTechRacing's Avatar
Stg 2
2.8
K&N intake
borla muffler
cat delete
tranny mount
60's
Maybe this mount instead:
http://www.turbotechracing.com/produ...33&idcategory=
Many state they like the TTR mount better, the Ingalls has had structural issues, where the brackets have bent (then it does not work)
Just another suggestion, to possibly save you some head aces in the long run.
Old Jan 7, 2009 | 09:19 PM
Razor564's Avatar
I would suggest the OTT rotated mounts i believe i have seen the best reviews for them and it is what i plan on getting when i get mounts.
