Lots of misfires, is this normal?
Old Oct 11, 2008 | 03:59 AM
firepinch's Avatar
With my GM Stage 2 and Rebel 3" intake, I can see on my Interceptor gauge that I get often some misfires. This happen most of the time when Im at idle, sometimes when I accelerate and strangely, almost never when I go wide open throttle. However, I don't get a cel because of that... so I can presume that this is normal? Should I replace my spark plugs? Why am I getting all those misfires?
Old Oct 11, 2008 | 04:14 AM
raptors_67's Avatar
did you swap PCM's? If you did (which I'm betting something like this) you will need a CASE relearn.
Old Oct 11, 2008 | 01:12 PM
firepinch's Avatar
No, not at all, because this is the stage 2 from GM. So the dealer did all the installation.
Old Oct 11, 2008 | 01:44 PM
burnrubr88's Avatar
Bump bc i have the exact same problem.
Old Oct 11, 2008 | 01:47 PM
Supercharged06's Avatar
could be bad plugs or a bad coil pack
Old Oct 11, 2008 | 01:50 PM
burnrubr88's Avatar
not to thread jack, but i just put new bkr7e in yesterday. before i was gettin as high as 26 misfires, and one night i hit 46. since the new ones went in, im seein anywhere from 4 to like 14ish. again sorry to thread jack, i hope both of us get some help.
Old Oct 11, 2008 | 01:54 PM
cobaltR's Avatar
hell....I'm stock and get alot misfires...I've just been too lazy lately to check my plugs..
Old Oct 11, 2008 | 02:08 PM
firepinch's Avatar
Oh I see that any of you get more misfires than me... but what I mean by a lot of misfires is that I get them often, but in a low quantity, like 2 to 4 misfires each time. Maybe this is normal? I would like some experienced users to clear this up if possible! This may be something to not worry at if this is something like me.
Those who get up really more misfires in this post, do you get a check engine light?
Old Oct 11, 2008 | 02:09 PM
burnrubr88's Avatar
nope, no cel. ill get 2 or 4 pretty often like at idle, while driving when i shift, i might get like 8, and a hard pull ill get like in the teens somewhere.
Old Oct 11, 2008 | 02:12 PM
firepinch's Avatar
Pretty much like me, except I never have any or I should say very rarely when I do some hard pulls
Old Oct 11, 2008 | 02:13 PM
burnrubr88's Avatar
actually now that im thinkin hard about it, i dont get hardley, if any durin a hard pull. usually the most i see like when i see a 16 or somehtihn is just normal driving. its so completely random. then a 2 or 4 at idel.
Old Oct 11, 2008 | 02:16 PM
cobaltR's Avatar
no cels...most get misfires at idle or occasionally just crusin.
Old Oct 11, 2008 | 02:18 PM
burnrubr88's Avatar
exactly the same here....
Old Jan 15, 2009 | 11:37 PM
Doubletg13's Avatar
same here..drives me nuts...i would really like to know what the problem is haha
Old Jan 16, 2009 | 12:09 AM
D1sclaimer's Avatar
I would recommend trying a different spark plug maybe? With my car there was a recall with faulty spark plugs that would cause serious misfires and load misfires.
Just a thought. Might not be the solution.
Old Jan 16, 2009 | 11:52 AM
Dainslaif's Avatar
I'm thinking it may be normal. My interceptor sees a lot of misfires at idle too. Burn, if you had 46 misfires and a P0300 code didn't get set, I'm thinking you're okay.
Old Jan 16, 2009 | 11:54 AM
cobaltBlackss's Avatar
Are you seeing any other codes?
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
717ssbalt
Oct 2, 2015 04:01 PM
SSLOW06
Oct 1, 2015 07:21 PM
