loud squealing
Old Jul 21, 2006 | 04:35 PM
03gobluecobra's Avatar
loud squealing
I just put on a new 3.15 pulley and a 76mm tensioner idler. Somehow I'm getting tons of squealing, which varies with rpm, and I think is coming from the belt. Any thoughts? I will try going back to the stock idler to see if that helps, but from my reading, the idler is supposed to cure the squeal.
Old Jul 21, 2006 | 05:24 PM
cashstacker's Avatar
If the belt is not centered it will squeel. When I put on my pulley I accidentely had the belt over one too many towards the right on the underdrive pulley and it was squeeling. Centered the belt and it quit.
Old Jul 21, 2006 | 05:52 PM
korax123's Avatar
Belt to tight???? You don't need a bigger idler when going to a 3.1"
3.0 is iffy and 2.9 and down for sure you need the bigger idler.
Old Jul 21, 2006 | 06:03 PM
I think it was off on the AC pulley, so I moved it over and it seems to be fixed now. Thanks for the help.
Old Jul 22, 2006 | 05:15 AM
no problem man glad all is fixed.
biniecki
Oct 25, 2015 02:23 PM
OrangeK
Sep 20, 2015 03:02 AM
bobbob160
Sep 15, 2015 11:31 PM
Infamous SC/SS
Sep 4, 2015 05:33 PM
Adam144
Sep 3, 2015 07:48 PM
