low boost and lagging power intense stg 3
well my intense stg 3 kit has been on for a while now, when i first put it on i would only reach 3-5 pounds of boost, well i couldnt never figure out why so i just bypass modded it, well i want to hook it back up for safety, but it still only reads 3-5 pounds, i think the silinoid for the bypass valve is gone, but not shure, and also with the bypass mod i get stumbling from the motor when i accelate, like it is not geting enough fuel, or somthing, could someone help me out, thanks
codes that i am getting are P0326 Knock Sensor (KS) Performance -PCM , and P0033 Supercharger Bypass Valve Solenoid Control Circuit -PCM,
PLEASE HELP ME!!!!!
PLEASE HELP ME!!!!!
yea i emailed todd at intense and he said that the bypass solenoid was bad or they sent me a bad ecu with the kit, so trial and error is in my future till i get it fixed i guess
When you see lower than average boost the positioing of the bypass valve can be to blame. I belive you push the bypass valve all the way down and tighten it back up. But, iver never heard of it being such a dramatic boost loss. Usualy it varys about 4 lbs from top to bottom position.
you could be getting timing pulled and boost loss from knock issues. Do you have a gauge that shows knock? I would definitely get one if you have an aftermarket tune so you can see if you're messing your car up. Also, if you're doing the boost bypass and you're running your car and its knocking, you might just be running your car into the ground.
Last edited by kawategra98; Feb 2, 2008 at 12:17 PM. Reason: Automerged Doublepost
a
could my fuel filter be clogging up causeing the hesitation, and that throws the knock code, i can get the code cleared and it runs fine for like 5 miles then the hesitation is back and the cel comes back on
yea i gapped them were i always have, but i have noticed since it has been really cold here the last couple of days i havent had any problems but yesterday it warmed up a little and the problems came back...........?
I almost guarantee its the Intense tune...when I ordered a custom PCM for my mods, it ran fine for a little while, but when I was on the Interstate and got on it in 4th gear, knock would go thru the roof...at that was at WOT.. I was seeing upwards of 12* of knock...
