Ls1 Maf
Old Jan 30, 2008 | 02:58 PM
Kennyspec's Avatar
Ls1 Maf
Hey who is it thats runing the LS1 or LT1 MAF on their car????? i need help with a "project"
Old Jan 30, 2008 | 03:00 PM
shabodah's Avatar
I thought it was easiest to use the LS4 or Colorado Maf (aren't they, in fact, the same?).
Old Jan 30, 2008 | 03:23 PM
BlackSS/SC's Avatar
It's me, it's a LS2 Maf. I'll get ya the part number.
Old Jan 30, 2008 | 03:25 PM
Co|3aLt $$'s Avatar
what the benefit of the different maf? (this does not include the tb...right?)
Old Jan 30, 2008 | 03:27 PM
BlackSS/SC's Avatar
GM #25168491, 5 wire direct plug in
PM sent btw
Last edited by BlackSS/SC; Jan 30, 2008 at 03:27 PM. Reason: Automerged Doublepost
Old Jan 30, 2008 | 03:52 PM
mike25's Avatar
do you have a pic of one of these? curious as to what it looks like
Old Jan 30, 2008 | 04:01 PM
BlackSS/SC's Avatar
Here's a pic
You just clamp it on.
Last edited by BlackSS/SC; Jan 30, 2008 at 04:01 PM. Reason: Automerged Doublepost
Old Jan 30, 2008 | 04:08 PM
Cobalt_SSTuner's Avatar
its workin pretty well for you?
Old Jan 30, 2008 | 04:09 PM
BlackSS/SC's Avatar
Have not got the car running again yet so I couldn't tell ya. Still putting everything together right now.
Old Jan 30, 2008 | 04:18 PM
Kennyspec's Avatar
thanks a lot man.
Old Jan 30, 2008 | 04:25 PM
SScobaltSC's Avatar
whats the benefit of changing the maf????
Old Jan 30, 2008 | 04:39 PM
BlackSS/SC's Avatar
For one you don't need to weld the MAF bung to the intake tube when going turbo. Also they are said to be more accurate.
Old Jan 30, 2008 | 08:02 PM
ptrblkz24's Avatar
Whats the diameter of that sensor,3"?
Old Jan 30, 2008 | 08:12 PM
BlackSS/SC's Avatar
IIRC the ID was 88mm when I measured it, but it's said to be 85mm. The couplers I am using are 3 1/2" ID on one end and 4" ID on the other and reduce down to 3".
Old Jan 30, 2008 | 08:15 PM
ptrblkz24's Avatar
oh,ok.
Old Jan 30, 2008 | 09:00 PM
not only are they said to me more accurate, but less sensitive if i'm not mistaken
Old Jan 30, 2008 | 09:15 PM
eastcoastz's Avatar
What kind of PCM changes need to be made to run this?
Old Jan 30, 2008 | 09:32 PM
mike25's Avatar
i dont believe any its a direct swap with the stocker...btw i look at it and i dont quite get what im looking at...what the stuff in the middle of the piping? the maf itself?
Old Jan 30, 2008 | 10:15 PM
spaz's Avatar
You have to recalibrate your maf table.
Old Jan 31, 2008 | 10:05 AM
BlackSS/SC's Avatar
^^^What he said^^^
Old Jan 31, 2008 | 12:20 PM
JMAc88's Avatar
People with small pulleys are moving so much air they were maxing out their maf, this will allow them to get better readings of the amounts moved.
Old Jan 31, 2008 | 12:43 PM
ralliartist's Avatar
this would be a good addition when bolting on the new TVS that harrop will be putting out soon.
Old Jan 31, 2008 | 12:44 PM
lsjwannabe's Avatar
i have never seen any supercharged people out run there table besides myself and thats becuase my maf is blown
Old Jan 31, 2008 | 09:08 PM
syP's Avatar
syP
how would the LQ4 MAF work on these cars?
Old Jan 31, 2008 | 09:12 PM
lnf08ecotec's Avatar
I keep getting p0300 misfire codes due to my Injen intake; if I upgraded to an LS2 MAF could this correct my problem? Also, does it just plug right up like described or would it have to be tuned to an LSJ PCM?
