ls4 tb installed
Old May 8, 2011 | 12:31 AM
dbr's Avatar
dbr
ls4 tb installed
well i read alot of reveiws, on the ls4 tb on our lsj's, and most of them if not all of them where negative. but from first hand experience, it's just like having a 7lbs flywheel and upgraded clutch. you just gotta find its sweet spot then your golden.
it's doesn't give you alot of hp, but it make the the hp you already have useful aagin
Old May 8, 2011 | 12:33 AM
Joemaster70's Avatar
So your saying get a LS4 TB?
Old May 8, 2011 | 12:41 AM
dbr's Avatar
dbr
if your willing to live with it and undrstand what it's doing to your car, then get it. but if you just want an upgrade to instantly work no questions asked.....don't.
you'll get use to it in about a weekend.
07BoostedG5's Avatar
probably a good match to a port and polished sc
its just real sensitive?
Old May 8, 2011 | 12:42 AM
dbr's Avatar
dbr
zzp did that too
Old May 8, 2011 | 11:38 AM
Frew's Avatar
Not worth it, even with proper scaling it is still sucky in stop and go driving, I live in pittsburgh and it made me wanna pull my hair out, I can imagine it being a little easier to deal with in the country or rural areas, in short if your the type of person that changes throttle positions quickly this is not the throttle body for you
Old May 8, 2011 | 11:45 AM
BLAZIN07SS's Avatar
I'm too JDM for you
so you know zzp made 898whp on a smaller than stock lsj throttle body? ls4 is a waste of time IMO
Old May 8, 2011 | 02:36 PM
Frew's Avatar
This, only thing I like about it is in a parking lot in first you could just tap the gas and chirp the tires like a big torquey v8, people would look over and see this cobalt, it was always lulz
Old May 8, 2011 | 02:54 PM
100% METH's Avatar
amazing what happens when your boosting 54 lbs
Old May 8, 2011 | 08:28 PM
dbr's Avatar
dbr
well it really doesn't matter what zzp made on a smaller or bigger tb, to me 54lbs of boost is still 54lbs of boost. they probably put a smaller tb on to regulate air flow a little better then having 890hp just hit u in the face as soon as you touch the pedal. imo!
but everybody has the veiws on it, i like the throttle response.
Old May 8, 2011 | 09:00 PM
06SS ALL DAY's Avatar
ls4 is only useful if your intake mani is ported otherwise the air ur sucking in is going in at the SAME volume as it was with the stock tb. its just more sensitive. think of it like as getting a *******. she can open her mouth wider but shes still gonna gag.
Old May 8, 2011 | 09:16 PM
BLAZIN07SS's Avatar
I'm too JDM for you
hit you in the face? that thing spools late as ****. but as you said everybody has different views. have fun in school zones and traffic
Old May 8, 2011 | 09:20 PM
ecot3c inside's Avatar
reading this ^ then your sig, is epic.
Old May 8, 2011 | 09:32 PM
Omnigear's Avatar
another non factual statement for the ls4 =p
Old May 9, 2011 | 12:51 AM
dbr's Avatar
dbr
lol! everybody just chill out, i'm just sayin that ls4 tb's are out of the ordinary, we all now that. i look at it as a step in the right direction as far as future modding goes. i have no problem driving my car with or without the tb. i can adjust to it easy in traffic or school zones and not look like a tool lol!
Old May 9, 2011 | 09:34 AM
mrbelvedere's Avatar
you can make a ls4 drive like a stock tp for the bottom to mid its worth it if you mess with it
Old May 9, 2011 | 01:21 PM
Rodimus_Prime's Avatar
^what changes did you do to make that happen?
Old May 10, 2011 | 10:37 AM
dbr's Avatar
dbr
i dunno what you gotta do but turbo tim a zzp did mine. i guess it all depends on the tuner mostly, because this mod will always have promising results with a good or bad tune.
Old May 10, 2011 | 08:30 PM
stonny9's Avatar
I just keep it in second or first if I am around the high schoolers.
Old May 10, 2011 | 11:56 PM
dbr's Avatar
dbr
yup, that works too.
Old May 12, 2011 | 02:39 PM
red06SC's Avatar
unfortunately for you, to physics - it isn't
Old May 12, 2011 | 10:38 PM
dbr's Avatar
dbr
^it was a figure of speech. lol it is what it is i guess.
Old May 12, 2011 | 10:45 PM
N1ckateen's Avatar
not when she doesn't have gag reflexes.
Old May 13, 2011 | 12:01 AM
thebucky84's Avatar
i recently just changed back to the stock TB, that LS4 one was giving me a headache to dial in. Not worth it IMO
Old May 27, 2011 | 05:42 AM
100% METH's Avatar
literally bolted it on and readjusted the afr to match the fuel curve on the stock tb. Did 3 pulls on each throttle body and took the highest hp of each to get this.
it doesnt just make more @ peak zones either, its more power over the entire rpm range.
considering how cheap some of us get these for... to bolt it on and gain 9whp... money well spent.
