LS4 Throtle body yes or no?
Old Sep 21, 2009 | 06:04 PM
StreetLC's Avatar
I am curious to know if an LS4 tb would benifit my car or no?
my mods are 2.9 pulley, 42lb injectors, Gmpp header and exhaust, zzp cattless DP, heat exchanger, zzp tune, and 75 wet shot of nitrous. What do you guys think?
Old Sep 21, 2009 | 06:07 PM
WVsuperSS's Avatar
interested
Old Sep 21, 2009 | 06:19 PM
Black SS 07's Avatar
i hear good and bad things about it.
i have one laying around here that ive been meaning to put on but you need to retune the ecu for the flow change..
in theory it should beifit you because of the size difference but from what i hear it can change the flow of air in a bad way.
Old Sep 21, 2009 | 06:21 PM
Jared B's Avatar
just port and polish the stocker you will see better results.
Old Sep 21, 2009 | 06:22 PM
WVsuperSS's Avatar
so like every other performance mod you just need to get your computer tuned for it.... no biggy
Old Sep 21, 2009 | 08:50 PM
rcorona8's Avatar
Where can i order TB LS4 FROM? what else is needed besides a tune.
Old Sep 21, 2009 | 09:31 PM
johnladow07's Avatar
I have it and it definetly feels like more power down low, but I read alot about air reversion....
Old Sep 21, 2009 | 09:32 PM
the spacer.. www.zzperformance.com has both or just look in the for sale ad's on this site.. i think theres one on there right now
Old Sep 21, 2009 | 11:56 PM
SlowLSJ's Avatar
i have one, works just fine lol
no issues drives fine
i say i picked up about 10HP MAYBE
Old Sep 22, 2009 | 05:24 AM
ralliartist's Avatar
tq is the biggest gain from it. If you tune for it, it'll drive just like stock.
Old Sep 22, 2009 | 05:26 AM
Zach06CobaltSC's Avatar
Air reversion isn't an issue on the m62, with the TVS however it is.
Old Sep 22, 2009 | 05:34 AM
eurochevy's Avatar
there will be tons of ppl saying yes and tons saying no honestly depends if u wanna tune it or not cause apparently its a pain...obviously the higher hp guys / tuners and personal tuners have had success with what they have so going more towards what thoughs guys have can give you an idea of whats possible / isn't possible i like ot mention area47 cause hes extremely good for what he knows which is a lot fyi
Old Sep 22, 2009 | 05:49 AM
It's not a pain to tune for at all. It IS a pain to use without a tune though.
If you want my opinion, I say stick with the stock tb unless you are upgrading to a 3 inch intake like ottp's, then it might be cool to use.
Either way there are better things to spend your money on then a throttle body, I would start elsewhere.
Old Sep 22, 2009 | 05:55 AM
Dayta's Avatar
nope
Old Sep 22, 2009 | 06:02 AM
Steven Flit's Avatar
pretty much a expensive 200 dollar mod, that gives slightly increased low end throttle feel.
set the scaler to 4950 in hpt, and it drives like a normal Tb.
The gain I felt was just to minimal to justify spending 200 dollars.
Spend the cash on stg1 rotated mounts or stg1 axles instead; a much better investment IMO
Old Sep 22, 2009 | 06:12 AM
200 dollars? wow, 40 dollar mod here and well worth 40 bucks.
Old Sep 22, 2009 | 06:19 AM
nicksredline's Avatar
where are u geting 1 for 40 buckS?
Old Sep 22, 2009 | 06:29 AM
You can pick up used ls4 tb's pretty cheap if you know where to look, granted he did get a pretty solid deal. They usually go for a little bit more then that, but if you look around you can get them for less then 75 bucks usually.
Old Sep 22, 2009 | 06:57 AM
Got mine off someone selling it on the board. But I've seen them on ebay for 50-60 bucks and I've also found them online at car-part.com
Old Sep 22, 2009 | 10:24 AM
Tennpenn83's Avatar
agreed. got mine for 50 shipped. don't know why you spent 200
Old Sep 22, 2009 | 02:46 PM
$100 for the adapter plate via RAW
$100 for the LS4 TB from ZZP
Old Sep 22, 2009 | 02:52 PM
Supercharged Guy's Avatar
With the mods that you have the ls4 tb is most likely going to help you out just when you put it on go and get it tuned right after....Im thinking about getting one too so let me know
Old Sep 22, 2009 | 03:01 PM
StreetLC's Avatar
Tuning isnt going to be and an issue. Is it a better idea to run a CAI with the TB or does it matter?....i use the air box mod for now.
Old Sep 22, 2009 | 03:03 PM
Jn2's Avatar
Jn2
ive been debating the ls4 for so long now, having more displacement and highe r compression it may help me more than a 2.0...
Old Sep 22, 2009 | 03:04 PM
having that adapter plate completely negates having the LS4 TB.
