LS4 throttle body and intake discussion
Old Oct 24, 2008 | 11:47 AM
  #51
2K5SS/SC?'s Avatar
Has anyone hacked an Injen intake and hooked it up to this TB yet? If so, just curious how you did it since I've had my TB sitting in the garage for a few months now and haven't tried rigging something up yet.
Old Oct 24, 2008 | 11:49 AM
  #52
ralliartist's Avatar
Originally Posted by LopsidedJester
a 3.5" intake probably won't help anything, it won't fit, it'll throw off the MAF, plus with the 3.5" TB, the inner smallest diameter of the TB is about 3" or even slightly less, not 3.5". 3.5" is the outer diameter of the TB. So, 3.5" would just be a waste
dur dur, I feel dumb now. Someone go measure the inside of their ls4 throttle body. I'm curious as to what it is now.
Old Oct 24, 2008 | 11:50 AM
  #53
Altiery54's Avatar
lolz would u like me to try? i'm waiting for my R.A.W. 3" Intake to put my ls4 on. but once i get it i will hack some **** up 4 testing reasons
i work till 3 and am huntint after that till 8 but u shall have a PM around 830 my time and i'll let ya know
Old Oct 24, 2008 | 11:57 AM
  #54
quadracer0387's Avatar
i want a 3.5 intake.... got the tb and harrop and ordered a ported mani...
ralli, if you make one let me know
Old Oct 24, 2008 | 11:58 AM
  #55
lsjwannabe's Avatar
all you need is a 3" to 3.5" coupler nothing crazy
Old Oct 24, 2008 | 12:07 PM
  #56
ebristol's Avatar
True.
ETC Scaler Setting
Stock TB
LS4 TB
Old Oct 24, 2008 | 12:28 PM
  #57
i need the inner diameter measurement first to properly size an intake.
btw, i can't read those cad drawings ebristol. my brain doesn't comprehend. lol
77 +/- .5 mm right?
Last edited by ralliartist; Oct 24, 2008 at 12:28 PM. Reason: Automerged Doublepost
Old Oct 24, 2008 | 12:30 PM
  #58
Omega_5's Avatar
77 +/- .5 mm right?
Correct.
LS4 TB = ~77mm +/- .5mm
... that's why everyone just runs a 3" intake...
We call it a "3.5" TB"... but that's the average outside diameter. The ID is 3.03"
Old Oct 24, 2008 | 12:45 PM
  #59
ahhhhhhh, I see says the blind man. LOL. Great learning experience.
Old Oct 24, 2008 | 12:50 PM
  #60
ebristol's Avatar
You know...for someone with almost 5K posts you should already know this stuff! lol jk
Old Oct 24, 2008 | 01:03 PM
  #61
ehh, it hasn't been talked about a whole lot. And I was really researching cooling mods hard core for the first 4K posts. lol.
I didn't even realize that I have that many posts. LOL.
Old Oct 24, 2008 | 01:05 PM
  #62
M88ArRamadi's Avatar
subscribed
Old Oct 24, 2008 | 01:09 PM
  #63
JimzSS's Avatar
click and learn for me.
Old Oct 24, 2008 | 04:14 PM
  #64
Rodimus_Prime's Avatar
I thought this was determined to be a worthless mod? guess ill have to revisit this idea
Old Oct 24, 2008 | 04:30 PM
  #65
Omega_5's Avatar
I was under the impression that almost every TVS guy was running an LS4 TB, as the throat is big enough to accept it without modification.
Old Oct 24, 2008 | 04:31 PM
  #66
maybe thats my problem lol
Old Oct 24, 2008 | 04:32 PM
  #67
SCBLKRL's Avatar
lol...if it is...then that must be a problem for me as well.
Old Oct 24, 2008 | 04:38 PM
  #68
06black's Avatar
i'm going to avoid reading all this and just chime in.
the only time this larger TB would make any effect is if your maxing out the stock 6X mm tb
i HIGHLY doubt any of the blower cars are doing this.
theres a substantial vacuum being pulled on the incoming air.
the reason people report AFR changes is due to maf cal's being off now that you've changed a piece of your intake.
also, if your intake is ANY bit smaller then the tb, you loose that effective area. fluid flow, simple.
the power jumps are often caused by the uneducated simply not knowing that your approaching and passing 100%VE quicker, with less TPS due to the larger butterfly plate.
the add'ed harshness down low is associated with that same function^^^^^
now, granted this isnt apples to apples, as i'm pushing pressurized air, and you guys pull atmospheric pressure....but none the less, i'm using an OE tb on my intake manifold...she makes pretty good power i'd say.
Old Oct 24, 2008 | 04:44 PM
  #69
2K5SS/SC?'s Avatar
That's what I have been waiting on myself! I guess they ran out of MAF bungs and just got them in as I was told literally a few minutes ago. I was thinking of hacking mine up somehow as well since my original Injen has seen better days!
Old Oct 24, 2008 | 05:50 PM
  #70
csementuh's Avatar
OK, soo it this being deemed a useless mod again..? I was under the impression that my tune did not use VE but only used the MAF...
Also if the cold air intake is now the "restriction" then the RAW is still a 3" intake..? Soo your telling me that there is no power to be made with the LS4 TB and a CAI, when a CAI makes power on it's own..?
Old Oct 24, 2008 | 05:53 PM
  #71
06black's Avatar
if the motor adn blower were perfect, that is, if they used all the air we bring in, then what ever the smaller piece is (cai or tb) wold be your restriction.
most of the time its the CAI, however the blower inlet, and the blower its self, along with the cylinder head, cam design, and intake manifold all pose significant restrictions.
Old Oct 24, 2008 | 05:55 PM
  #72
Omega_5's Avatar
First... your ECU uses both the MAF and VE tables to calculate air flow, unless your tuner changed the dynamic airflow settings.
Second... if your intake is smaller than 2.75"... it's the smaller diameter than the TB... thus more restrictive than the TB.
However... it's not THE restriction in the system.
If you are making enough power to cause a vacuum in the intake strong enough to cause power loss than the bigger TB and a 3" intake would benefit... hence why I suggest it only to people making big power.
Old Oct 24, 2008 | 05:59 PM
  #73
csementuh's Avatar
Well I'm pretty certain my tuner said that the VE is disabled as the MAF is more accurate or something. It was tuned by Dan djt81185 soo whatever he does...
I understand that there are many other restrictions in the engine...
The intake is a RAW, which is supposed to be 3" ID I believe.
And once again, I would like to ask if my present mods justify this TB and CAI combo...? I was assuming I got some gain, as it "feels" like it...
Old Oct 24, 2008 | 06:02 PM
  #74
Omega_5's Avatar
Dan's a good tuner... if he disabled it.. it's gone.
As far as the TB & CAI... the only way to tell is to try it. Every car is different.
Old Oct 24, 2008 | 06:05 PM
  #75
csementuh's Avatar
Thanks for the info. It seems to be doing "something" for the car. It feels a bit faster and the response is nicer.
