LSJ Compression Testing & Numbers Info
Old Jun 1, 2010 | 07:58 PM
recklessactn's Avatar
Exclamation LSJ Compression Testing & Numbers Info
There has been some off and on information passed that compression number range between 180-220 on the LSJ engine. This is dependent upon whether or not you have done internals work but for the most part I believe compression testing on our cars is a great tool to use if you believe your engine has encountered a problem and have ruled out all other possible solutions or you just have beaten on your car alot and want to see how it has held up at xx,xxx+ amount of miles. I blew a head gasket and did not realize this until I compression tested and figured out what had happened. Since having one and modding other peoples cars, I have voluntarily asked them if I could test their cars compression to compare against others and mine. Well after doing 12 different LSJ cobalt's from the tri-state area I have some pretty definitive numbers I stand by. Only 1 car out of 12 had different numbers other than 215/220-220-220-220 compression. The other car had run 12 bottles of nitrous through the car and had compression numbers of 205-210-200-210. The cars tested had various miles on them and different mods (no internals work, stock longblock), but the results speak for itself and if you should find yourself looking for a benchmark use these numbers, if your number come out differently, its not necessarily bad if they are all with +/- 5-10% of each other.
Cliff notes: 11 out of 12 LSJ's compression tested at 220 across. Useful information on diagnosing engine internal wear/damage.
Old Jun 1, 2010 | 08:01 PM
ford's Avatar
Good info.
Old Jun 1, 2010 | 08:02 PM
damien's Avatar
so tomorrow ill come over and we can do mine?!
Old Jun 1, 2010 | 08:03 PM
chevysssc's Avatar
Originally Posted by recklessactn
There has been some off and on information passed that compression number range between 180-220 on the LSJ engine. This is dependent upon whether or not you have done internals work but for the most part I believe compression testing on our cars is a great tool to use if you believe your engine has encountered a problem and have ruled out all other possible solutions or you just have beaten on your car alot and want to see how it has held up at xx,xxx+ amount of miles. I blew a head gasket and did not realize this until I compression tested and figured out what had happened. Since having one and modding other peoples cars, I have voluntarily asked them if I could test their cars compression to compare against others and mine. Well after doing 12 different LSJ cobalt's from the tri-state area I have some pretty definitive numbers I stand by. Only 1 car out of 12 had different numbers other than 215/220-220-220-220 compression. The other car had run 12 bottles of nitrous through the car and had compression numbers of 205-210-200-210. The cars tested had various miles on them and different mods (no internals work, stock longblock), but the results speak for itself and if you should find yourself looking for a benchmark use these numbers, if your number come out differently, its not necessarily bad if they are all with +/- 20 of each other.
Cliff notes: 11 out of 12 LSJ compression test at 220 across. Useful information on diagnosing engine internal wear/damage.
where have u been? u going to Hooters 3
Old Jun 1, 2010 | 08:04 PM
check out other thread
https://www.cobaltss.net/forums/show...32#post4983232
Old Jun 1, 2010 | 08:09 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i feel special that i ran 24 bottles of nitrous through my car and maintained 220psi across the board! lol
chevysssc's Avatar
great write up to bad the people who need it wont read it.
Old Jun 1, 2010 | 08:11 PM
Good stuff, your engine must of been made by the cobalt gods
Old Jun 1, 2010 | 08:57 PM
BLAZIN07SS's Avatar
I'm too JDM for you
thats what i am hoping for
Old Jun 1, 2010 | 09:00 PM
chevyracing's Avatar
Mine was 185-190-185-190
Old Jun 1, 2010 | 09:09 PM
sundevil07's Avatar
mine is *drumroll* 160-195-205-210 dry. wet its 210's across the board... i need new rings
Old Jun 1, 2010 | 09:51 PM
Frew's Avatar
200 across the board =-D pulled the head off for the ported one and the number 4 had some carbon build up in the center, looked like detonation, took a scotch brite pad *whistle* all better
Old Jun 2, 2010 | 01:08 AM
Area47's Avatar
Rent me! per hour
this varies gauge to gauge. go by the percentage difference between cylinders.
Old Jun 2, 2010 | 07:38 AM
shroogis's Avatar
Ding ding ding. This topic is irrelevant if you aren't using the same gauge. I have used 2 different gauges and got 10psi difference between 1 gauge and the other. My car makes 190-195psi on my gauge between all 4 holes.
Old Jun 2, 2010 | 01:50 PM
^^ good stuff and yes it was all done with the same gauge. Ill see if I can get another gauge to support your info. Would like to just see some consistency in the numbers.
Old Jun 2, 2010 | 10:54 PM
Area47's Avatar
Rent me! per hour
my comp numbers have varied from +/- 25psi depending on the gauge.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
