LSJ ECU/PCM and wiring harness year compatibility
Old Jan 27, 2012 | 06:52 AM
alanoo's Avatar
Well, I need some help on this for a swap in a totally different European vehicule.
I understand reading various things here, than depending on the year the LSJ PCM is different. It is just a software thing ? Or are the connectors and engine wiring harness different ?
Basically as I need to source a LSJ engine wiring harness, I need to know if I have to look to a specific year one to work with a specific PCM year or not ?
If it's just software stuff I'm sure Hptuners would do the job fine...
Anyone could brief me on that ?
Thanks
Old Jan 27, 2012 | 08:39 AM
Speedytec's Avatar
From what I learned here, I think only the '07 LSJ pcm operating system has some significant differences compared to the 05-06 years. (Right?)
Harness and connector-wise all should be identical. (Although an 04 Ion Redline uses an axle mounted VSS sensor and on the later years it's in the gearbox.)
I never got a definite answer which OS was the best, but all should be suitable for your rear-engine swap and tunable by HPTuners. ;-)
Old Jan 27, 2012 | 11:23 AM
Pyros777's Avatar
There is no physical difference in the PCM. The 07 OS has differences in the way the tables are formatted/located, but nothing that a Write Entire would not resolve if you wanted to load an 05 or 06 tune. All wiring should be the same 05--07.
You may have heard that 07 had a different PCM, but that only applies to the P12 found in the Colorado/Canyon/Trailblazer, etc. (Vortec/Atlas applications of this PCM). That one is 2MB as opposed to the 1MB found in all other makes/models (i.e. - Cars). There isn't really sufficient documentation on this though, so you may be best off sticking to 05-06 to source your parts as they are guaranteed to be most compatible with each other.
ineedacobaltss
Nov 7, 2015 02:25 PM
Builttss
Oct 4, 2015 10:21 AM
Sep 27, 2015 08:53 PM
jrocstar
Sep 26, 2015 11:42 PM
Coballin13
Sep 25, 2015 08:43 AM
