LSJ info
Old Apr 25, 2006 | 11:34 PM
boosted06's Avatar
LSJ info
Where can I find the engine specs on my 2.0L , like compression , bore, stroke etc ?
Old Apr 26, 2006 | 09:40 AM
boosted06's Avatar
no one knows ?
Old Apr 26, 2006 | 09:48 AM
p7x's Avatar
p7x
Engine: Ecotec 2.0L SC (LSJ)
Type: 2.0L supercharged/intercooled inline 4-cylinder
Displacement (cu in / cc): 122 / 1998
Bore & stroke (in / mm): 3.39 x 3.39 / 86 x 86
Block material: cast aluminum with cast iron cylinder liners
Cylinder head material: cast aluminum
Valvetrain: chain-driven dual overhead camshafts with roller followers, 4 valves per cylinder, dual rotating balance shafts
Ignition system: coil-on-plug coil-on-plug
Fuel delivery: sequential fuel injection
Compression ratio: 9.5:1
Horsepower (hp / kw @ rpm): 205 / 153 @ 5600
Torque (lb-ft / Nm @ rpm): 200 / 271 @ 4400
Recommended fuel: 91 octane unleaded
Maximum engine speed (rpm): 6450 fuel cutoff
Emissions controls: 3-way catalyst (Tier 2 LEV 2 Bin 8 )
Estimated fuel economy(mpg city / hwy / combined): TBD
Old Apr 26, 2006 | 10:03 AM
boosted06's Avatar
you are the man , thanks a million . I'm currently working with comp cams to find the right cams for my car : )
Old Apr 26, 2006 | 10:40 AM
zinner's Avatar
Moderator Alumni
If you do a set of cams try to upgrade the springs as well. That will let you up the redline.
Old Apr 26, 2006 | 10:54 AM
boosted06's Avatar
yea I planned on it , I'm trying to finish my car by aug. for the GM bash so hopefully everything goes smoothly
Old Apr 26, 2006 | 06:44 PM
Nuclear's Avatar
nice info man
Old Apr 26, 2006 | 07:34 PM
WopOnTour's Avatar
THE best place to find that sort of data is the GM Powertrain web-site
http://media.gm.com/us/powertrain/en...g%20trans.html
Enjoy
(and dont forget to check out the Chevy LS7 and Cadillac LH3 horsepower and torque graphs!! )
WopOnTour
Old May 1, 2006 | 01:45 PM
tiger's Avatar
what is the lsj
Old May 1, 2006 | 01:48 PM
memphisr24's Avatar
It's the name of our engine
Old May 2, 2006 | 06:23 AM
1fstss's Avatar
hmmmm i wonder if we can yank our balance shafts like i can in my DSM's
Old May 2, 2006 | 07:55 AM
Jmc007's Avatar
Anyone notice the maximum gearbox torque is written at 258 lb for the LSJ transmission ? That's only 29% more than stock ...
Old May 2, 2006 | 06:27 PM
WopOnTour's Avatar
Hard to do as you need the balance shaft chain to run the water pump (AND their bushing/bearings are part of the oiling system)
BUT GMPP offers a pair of billet aluminum "neutral" shafts to replace the stock shafts.
A bit pricey, and you will have to contend with a bit more engine vibration at lower RPMs
Wop
Old May 3, 2006 | 04:06 AM
Gory's Avatar
wow that 07 2.0 ecotec for the soltice is wild the torque band looks like this
___________________________________________
flat lol
Old Jul 6, 2006 | 02:11 AM
mhump428's Avatar
Does any one know the Hp/torque amount that each part can handle ??(i.e. cams block connecting rods pistons ect.)
Thanks
Old Jul 6, 2006 | 02:29 AM
Cobalt_Supercharged's Avatar
flat lol
Did you also notice that the Trans is the same as the Colorado, Sky, Solstice, Hummer H3 and is rated at a "Maximum engine torque: 258 ft/lbs"
The block construction is also impressive.
Old Jul 6, 2006 | 04:31 PM
InfiniteEffect's Avatar
LSJ = LS Jr.
Old Jul 6, 2006 | 04:41 PM
big_mike's Avatar
http://www.new-cars.com/2005/chevrol...alt-specs.html
Seemed to be QUITE informative on the entire vehicle.
Old Jul 6, 2006 | 04:55 PM
cavingman's Avatar
manual.lsjowners.com
some good info i compiled in there too
Old Jul 6, 2006 | 05:05 PM
maxpit's Avatar
LSJ springs have have rated at 7500rpms, along with valves and retainers.
Old Jul 7, 2006 | 03:32 PM
SchwarzCamaroRS's Avatar
Originally Posted by InfiniteEffect
LSJ = LS Jr.
lol, thats probably right... too bad our motors look and perform nothing like its bigger LS brothers....
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
dieGone
Oct 1, 2015 06:27 PM
Sep 28, 2015 12:51 PM
