LSJ MAP Sensor Part Number
Old Apr 10, 2010 | 01:50 AM
Pyros777's Avatar
Hi all,
I just had a heck of a time locating this part, and thought I would do everyone a favor by sharing.
The part number listed pretty much everywhere (GM dealers, gmpartsdirect.com, alldata, etc) for the TMAP on the LSJ is 12614973.
This is WRONG. I actually ordered this part number from gmpartsdirect.com, and was surprised when I opened the box to find they had sent me the Baro sensor instead.
A search of ss.net showed that this has happened before, but nobody ever found/posted the updated part number.
I happened to find this j-body.org thread:
http://www.j-body.org/forums/read.ph...=870&t=870#870
The number listed in that thread is: 90423637
...but I could not confirm 100% whether it was the correct sensor, so the search continued.
Searching by the Bosch part number on the label (0261230042) didnt get me an exact match, but I did find a cross-reference of part numbers for this part:
Bosch 0261230042
GM 93170309
Opel 1238244
Fiat 46769978
I had already tried Bosch, but had not seen that GM number before.
It didn't work when I plugged it into gmpartsdirect.com, but another google search for 93170309 did the trick!
It is listed as a SAAB 2.0T part pretty much everywhere, and rightly so since the SAAB LK9 is the LSJ's twin brother.
SO, if anyone finds themselves needing an LSJ MAP sensor, but the dealer and all other usual sources fail, you can order one here:
http://www.aboveallmotorwerks.com/Pr...3170309_S.aspx
If that link is no good by the time you find this thread, just try this google search:
http://www.google.com/search?q=93170309
You're bound to find it that way.
Hope this eventually helps someone!
Edit:
After re-reading the j-body.org thread I linked, it turns out 90423637 IS the correct number. Someone posted a pic of the sensor and the label matches ours (Bosch 0261230042).
LSJ MAP Sensor Part Number: 90423637
I'll leave the rest of my rant and just gray it out in case it comes in handy for anyone.
Old May 6, 2010 | 12:48 AM
RooTBeeR's Avatar
thanks, i been looking for one!
Old May 6, 2010 | 01:00 AM
ItalianJoe1's Avatar
i have a used one if someone needs it.
Old May 6, 2010 | 02:16 AM
RooTBeeR's Avatar
the map sensor for the intake mani? i cracked my stocker when i modified it to fit the tvs
Old May 6, 2010 | 02:23 AM
slvr 04 rl's Avatar
you could just use the 3 bar map sensor, its way cheaper..
Old May 6, 2010 | 02:37 AM
RooTBeeR's Avatar
but how easy is it to tune the 3bar?
Old May 6, 2010 | 07:04 AM
Zach06CobaltSC's Avatar
I have 2 stock 2.0 lsj map sensors if anyone needs them . I would be willing to let them go at a very reasonable price too =D.
Old May 6, 2010 | 10:53 AM
Pyros777's Avatar
Yeah miles, I was actually using the GMS1 map for a while there. Worked like a charm, but the idea is to fix this GM part number mixup so people looking for a 100% stock replacement can know the proper number.
Old May 6, 2010 | 02:42 PM
Yeah, the one that the TVS crushes
Old May 6, 2010 | 02:46 PM
slvr 04 rl's Avatar
oh ok well then you did the job. i also had a heck of a time finding the part number. as far as tuning the 3 bar, idk, i dont tune my car but it was a few setting changed and it works good.
Old May 6, 2010 | 05:45 PM
Pyros777's Avatar
LOL yeah thats why I needed this one.
Yeah, its just two settings to make the GMS1 sensor work. Since its lower resolution it cant really read anything below 40kpa accurately, but it gets the job done.
Old May 6, 2010 | 08:16 PM
Jrhdpaintball's Avatar
so has anyone ran a 3bar sensor on a lsj?
Old May 7, 2010 | 12:15 AM
Pyros777's Avatar
Do you mean an actual 3bar tune, or just a 3bar sensor calibrated to work exactly like stock?
I've only ever used the latter..
Street Dreamz has a thread about 3 bar tuning, but it lacks just enough information to make it pretty much useless.
Old Sep 16, 2010 | 03:01 PM
csementuh's Avatar
Sorry to bump this old thread... But I am having problems with my TVS crushing my MAP as well.
I had the MAP rotated and not screwed down to fit under the TVS. I believe this was giving me a small vacuum leak, so I dremeled the MAP like crazy and cut a notch in the base to get the bolt to seat against something. I still have the leak I believe lol.
Did you guys mod the MAP or just rotate it?
And for a replacement, is it better to go with the 3bar MAP? I saw the 3 bar tune writeup, and ya that looks a bit stupid. If the 3 bar can be used on the regular tune with some setting changes, and is cheaper, it might be a good alternative.
Old Sep 16, 2010 | 03:10 PM
Pyros777's Avatar
The 3bar loses some resolution, so its actually better to stick with the stocker. You can't beat the GMS1 sensor for the price though.
Like I said I ran this MAP until I got ahold of another stocker.
If you want to run it in your car just change your Linear value to 329.43750, and your Offset to -6.35156.
BTW I also have a mystery vacuum leak. I've back and forth with it because I also have an exhaust leak from my CTI header not behaving, but I need to slap my M62 back on so I can clamp down the stocker to be 100% sure.
Old Sep 16, 2010 | 03:12 PM
csementuh's Avatar
Thanks for the info. So regarding the stock TMAP, did you dremel it to fit better, or did you just rotate it and have the TVS holding it down?
Old Sep 16, 2010 | 03:14 PM
Pyros777's Avatar
I dremeled the !#%@@!$ out of it.
Actually it came out nice and clean, very close cut, but thats the part that concerns me. I think having a little material around the edges for the TVS to smoosh might be necessary.
Old Sep 16, 2010 | 03:16 PM
csementuh's Avatar
I think I'm having the same problem lol. Mine looks nice as well, but I think there is something preventing it from sealing up perfectly. If I spray a bunch of brake parts cleaner on it, my idle dips a hair. I haven't tried it in awhile though, so I'll have to play with it more.
I wonder if a little bit of silicon around the oring and where the sensor seals onto the intake manifold, might fix it right up?
Old Sep 16, 2010 | 03:22 PM
Pyros777's Avatar
Yeah mine is pretty sporadic. Sometimes I will pull a perfect -20inHg of vacuum, but then other times I'll only do -15 and it begins to idle like crap. That is with the A/C OFF. A/C on makes it touch -10inHg and my idle starts bouncing non-stop. :\
A little silicone in there to help seal it would probably do the trick if that is in fact the issue. I might try it next weekend when my OTTP intake comes in.
Old Sep 16, 2010 | 03:35 PM
csementuh's Avatar
Sounds good. I'll have to try to fix mine soon. I usually pull about 16-18inHg at idle so I'm not sure if there is really a problem or not. My STFT's fluctuate like crazy at idle sometimes though, so I'm thinking maybe it's a leak. My front O2 looks good on a HPT scan and it switches properly, so I don't think that's it.
Good luck lol.
Old Sep 16, 2010 | 03:51 PM
Pyros777's Avatar
I've read that anywhere between 16--20 is normal, yet I know for sure a perfectly running LSJ should pull -20. That doesnt sit well with me. I want perfection. lol
Definitely hit this thread up again after you tweak it, and I'll post up too when I do mine.
Old Sep 16, 2010 | 03:56 PM
csementuh's Avatar
Sounds like a plan. I'd love to get mine straightened out as I feel like I have some tiny issue that is impacting me from getting my tune dialed in well. A small vacuum/boost leak would be enough to skew fuel trims and such.
Old Sep 19, 2010 | 02:04 AM
Sizzle06's Avatar
So you think i should switch back to the stocker Steven?
Old Sep 19, 2010 | 04:55 AM
Pyros777's Avatar
Not if the GMS1 sensor isn't giving you any probs. The loss of resolution doesn't seem to be affecting you so far. lol
Technically speaking though, the stocker is the best choice.
Old Sep 29, 2010 | 02:32 PM
Pyros777's Avatar
I replaced my rebel with an OTTP intake and now my car mysteriously pulls -20inHg again. Its more like 19.5, but it is VASTLY improved. I'm still trying to make sense of it.
