LSJ Normal Oil Usage?
Old May 16, 2012 | 08:23 AM
MustangGtKiller's Avatar
Hi Guys,
I just took my 06 SS/SC on a trip across the country. 3.5 K miles in total. When I checked my oil upon return, i noticed the oil level was down a bit on the stick, but above the minimum level. I did not change the oil, so I do not know for certain if it was within range in the first place. Do these engines use a oil in general? I do not smell oil burning, See blue smoke, or have any leaks. Engine feels strong. Last pass on a quarter mile was a 13.77 with a few entry level mods.
Thanks!
Old May 16, 2012 | 08:33 AM
yea mine will burn up through a little less than a quart over the course of 3000 miles usually
EDIT: I have no leaks, no blue smoke, car runs perfect at 50000 miles
Old May 16, 2012 | 08:35 AM
nismopowerdqg's Avatar
it is very common for a motor to consume oil over a couple thousand miles. if it burns around a quart that would be normal in the eyes of most mechanics between oil changes. so unless you smell it or see it going some where i wouldnt worry about it unless it started to consume an ungodly amount between oil changes. hope this helps.
Old May 16, 2012 | 08:56 AM
K-Train04RL's Avatar
All engines consume oil. Some more than others.
Old May 16, 2012 | 10:25 AM
mrbelvedere's Avatar
a 4 cycle engine will nayuraly consume oil oil gets pulled in from the valve guides and burnt and oil left on the cylnder walls gets burned during the combustion procces also if things dident get oil the engine would lock up and valves would stick
Old May 16, 2012 | 02:04 PM
you Guys are awesome!! Thanks! Also, I do not have a cold air intake. ( bad on me) what do you recommend. Does it make an improvement?
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Trav3480
Oct 1, 2015 08:17 PM
