LSJ Turbo Injector Size
What size injectors are needed for a lsj turbo. I have 60lbers with a t3/t4 50 trim turbo. Its blow through maf with a vulcan intake manifold. I flow about 47lb/min maf if that helps any. On a recent log in hp tuners my idc's were well over 125%. I figured 60's where enough.
do you log your car any idea what your idc's are around or what your seeing across the maf. just trying to figure out if its the tune or am i really maxing out the injectors
well it looks like they didnt go much over 95% until my car decided it wanted to suddenly command 10.4 afr. so i need to find what table is causing it to command something other than 11.4 like its set up in pe
you're more than welcome to it if you want
yea i have it. but i didnt want to flash it on to the car yet since i still dont have a wideband yet. so i'm just tweaking what i have cause i know the fuel side is safe right now
then you know what the car puts down + you can get log files with your hptuners and send them to someone here for tuning... get all that stuff done in one shot and there's no question on anything
