LSJ Turbo Poll - Answer which turbo I should buy!
As some of you may know, I'm turbo swapping my LSJ. I'm in the beginning-mid range of my swap and I need to pick out my turbo TODAY!
I found a thread on here that compared the turbo's, but I cannot find it anymore. If someone can help me that would be great. Also, if you pick a turbo, please explain why you choose that one instead of the others! --- ENGINE SPECS: --- Stock Motor -- Stock Pistons, Rods, Etc. I want to be sitting at around 400hp, since I'm all stock motor. |
6262 or go home. LoL
Originally Posted by ULWizSS
(Post 6892797)
you already know my vote. 5431e
(Post 6892800)
(Post 6892800)
(Post 6892804)
This is the best option out of the two for sure.
Pte5557 billet
Pte5857
(Post 6892815)
Pte5557 billet
Originally Posted by FF_ace
(Post 6892834)
Pte5857
I would have add this in your poll make up my own decision
or just get the 6262 best snail out period |
(Post 6892845)
neither of which they make anymore :lol:
if you're really worried about it go with the 5531 on a .48. exact same turbine as the 54 just a 1mm larger compressor
6262 is too big for a stock engine. you won't be able to run it in it's efficiency. and the power you will make won't make up for the lack of a powerband. built engine? yeah it'll work great for 550-600. stock engine no there are better options.
its great period
^^ ya im running a 5857 dbb w/ .63 ar on my built motor full boost at 4500. Would like it closer to 4k
dbb at 4,500? holy shit..
Jesus that's late. My journal bearing s256et with the larger exhaust wheel hits 25.5psi at 3700rpm on stock motor...
even my 262 .70 didn't spool that late. it was more around 4200
Ya idk what the deal is
Bought the 5531E MFS
*mfs
Corrected
you've been looking at wastegates too much.
(Post 6893361)
what turbo manifold are you going to run?
