lsj turbo swap super high idle
Old Jun 29, 2013 | 06:26 PM
i944scania's Avatar
Hey just recently completed a turbo swap on my 07 lsj. Everything looks right and for some reason it idles super high like 3k. Throttle body only goes on one way, stock lsj throttle body/intake mani on zzp adapter plate. Revs if you give throttle. No check engine lights. Anyone have any issues with this
Old Jun 30, 2013 | 10:19 AM
mrbelvedere's Avatar
vacuum leak
Old Jun 30, 2013 | 02:17 PM
i944scania's Avatar
Can it be in the tune? I've got the top vac port going to the bov. And the compressor has a port I sealed and connected to the bottom of the wastegate. Connected brake booster hose to adapter plate. Still need to cap off breather port Idk what else it could be.
Old Jun 30, 2013 | 03:08 PM
try posting in the turbo lsj section
Old Jun 30, 2013 | 03:52 PM
jonathan923's Avatar
^^^this and I agree sounds like a vacum leak probably before or after the tb.
Old Jun 30, 2013 | 03:55 PM
Sharkey's Avatar
its going to be a vacuum leak, check you throttle body gasket, along with the adapter plate gasket. make sure you dont have a spare vacuum port you havent capped.
Old Jun 30, 2013 | 04:21 PM
i944scania's Avatar
Okay thanks I'll check. I have posted on the swap thread and don't usually get responses
Turbo Johnny
Feb 21, 2019 09:41 AM
CarbonFiberCobalt
Mar 16, 2016 02:51 AM
Tupp
Sep 29, 2015 11:07 PM
Josh@ottp
Sep 17, 2015 12:03 PM
Josh@ottp
Sep 8, 2015 10:18 AM
