LSJ valvetrain help
Old Jun 16, 2011 | 04:33 PM
Mike Barr's Avatar
LSJ valvetrain help
I have a Lsj valvetrain in my cavaliers l61 head and i was wanting to upgrade my cams and was wondering if anyone knew if id be able to run comp stage 3 cams on this valvetrain or should i bite the bullet and buy ferrera valves and gm racing springs
thanks
Old Jun 16, 2011 | 04:38 PM
mrbelvedere's Avatar
contact zzp and as for stg3 cams in a 2.0 they make power past 11,000
Old Jun 16, 2011 | 04:46 PM
Mike Barr's Avatar
well its in a 2.2 lol
Old Jun 16, 2011 | 04:58 PM
Frew's Avatar
Would you be looking for turbo or blower cams? I see your sig so im assuming turbo
ok so stg 3 is still gonna make power alot higher then you would ever be able to utilize i wouldent go past stg2 but still talk to zzp
Old Jun 16, 2011 | 05:13 PM
Mike Barr's Avatar
well i have stage 2 cams i was just gonna try and see if i could go bigger but if its not worth it then nvm lol
Old Jun 16, 2011 | 05:20 PM
if you can make use of them it will be
Old Jun 16, 2011 | 05:24 PM
newt's Avatar
LOL and where did you get that information??
Old Jun 16, 2011 | 05:25 PM
strait from zzp is where i got
On Thu 11/28/04 11:45 AM , "Turbo Tim" tim@zzperformance.com sent:
I will try to keep this short,Stage 1 cams are a great upgrade! With the shafts and balancer the engine will be able to rev to 8000 without issue. 350-360whp is fine for the stock block as long as it is dyno tuned and not setup ridiculously aggressive. Stage 3 cams are way to big, my Redline rev’d to 9500 rpm with a 2.4L engine, so on a 2.0L it would rev to 11000+ rpm and the rest of the car is not really setup for that right now.
Thank you for your business,
Turbo Tim
ZZPerformance.com
Old Jun 16, 2011 | 06:11 PM
newt's Avatar
Are these the same lift/duration as the comp stage 3? Cause they make peak power no where close to 11,000 rpm.
Old Jun 16, 2011 | 07:08 PM
on a n/a app they wont
Old Jun 17, 2011 | 08:22 AM
newt's Avatar
I know three people who have ran them with with a boosted application (two turbo and one supercharged) and made peak power near 7000rpm.
Old Jun 17, 2011 | 10:53 AM
i dont think its the same exact cam as what comp sells
Old Jun 18, 2011 | 10:21 PM
Leafydialupking's Avatar
Better way to ask the question, what is the max lift the stock lsj springs can take?
Old Jun 19, 2011 | 09:09 AM
who cares how much lift they can take they arent worth a dam for high rpm ops any way
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
