lysholm build from hell pt 1.5
so im now into the nothing but problems stage of my build... right now i have a shit ton of codes that need to be figured out p0502,p1183,p0121,p1101,p1182,p0520...and just found a little milky oil... brand new head gasket intake gasket..... im getting close to giving up on this build... any recommendations on what is the problem/problems?
I hate to hear that..
Originally Posted by chood711
(Post 6573032)
im open to help from anyone
send it down to james.. Im sure it may cost a couple hundred but he may be able to get it going
yea thats last ditch effort... hope i dont have to waste money for that tho
hope you have better luck than i did tho when u get yous here soon
Originally Posted by jittjoey
(Post 6573355)
Start with repairing the mechanical issues first. Water in the oil / oil in the water is never good. I am sure you will need to take the head off to inspect and find the issue. This is either going to be a head gasket issue or worse.
Codes are; P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem P0502 Vehicle Speed Sensor Low Input P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction P1101 MAF Sensor Out Of Self Test Range./KOER Not Able To Complete KOER Aborted P1182 Supercharger inlet pressure(scip) sensor performance - actual airpressure by the scip does not correspond to calculated airpressure for more then .5 seconds P1183 CAN BUS comunication issue I would bet that you have a ground issue causing all of these codes. |
well the 2 codes for the supercharger are expected as the sensor isnt plugged in or on the supercharger at all... so kinda narrows that donw a tad, but im going to do a test on my oil tomorrow and then qucik oil pressure gauge to make sure its there
Did you get the head machine before putting it back on with that new gasket?
Turn off the SCIP code if its not hooked up. Inspect the sensors that the codes are showing for. Ground is possible, but still inspect the sensors. |
Have the day of tomorrow gonna hook. Up oil pressure gauge make sure it's the sensor ad then work on the throttle body
i say get rid of the 1.6 and send it my way :)
You'd have some lulz with that blower
Originally Posted by 100% METH
(Post 6576636)
Originally Posted by SCcobaltSS
(Post 6573941)
What made you replace the HG? What HG are you using? |
Originally Posted by Edubs
(Post 6579322)
This^
so who feels like a fucking retard......This guy!!!! so the two codes for the oil sensor/switch are from the lack of oil cooler therefore i dont have the oil switch to plug into therefore causing those codes............So being the valedictorian doesn't mean shit when working on cars... something told me im missing the easy shit....so now were down to figuring out the throttle body codes and that should have them all covered
good to hear u figured some of it out! i'm waiting to see how this b***h runs and some dyno numbers. good luck with the TB issues
i meant to ask u that the other day when u texted me.. apparently should not have forgotten. keep pluggin away
throttle body issues are in the tune more than likely.. getting high idle codes and what not were things i dealt with when i had the ls4 and the car was idling at 11 to 1250 rpm |
im going to use my budies cobalt and steal his throttle body real quick to make sure its deff not the throttle body itself... i know that is 90% most likely not the problem but its a 20 mine item to swapp out so im willing to rule that out right away
ur not gonna wanna take off th stock one after its on there because its gonna idle and run a lot better lol
Originally Posted by 06_SIC_SS
(Post 6580058)
(Post 6580075)
no just thought u had an LS4.
