M62 Supercharger Seized?
Hi guys,
I tried searching around but couldn't find anything.
So my supercharger is seized.
I put on a 2.8" pulley, and 60's yesterday, and threw on a base tune for now. AFR was fine (a little rich to be safe), no KR, IAT2s were high but expected for a hot day and a 2.8" pulley (about 30+ than IAT1, but its 88 degrees here right now).
Drove around for about 50 minutes, trying to tune the car, make sure everything went smoothly.
No issues at all, did a couple wide open throttle pulls.
Then I was cruising, and the car make a squeak, and the RPM's just died.
Pulled the SC, and the snub won't turn.
Is this the bearings inside? And how would I got about fixing this issue?
Thank you, Owen
Thank you, Owen
Not sure if you mean snout?
Got the snout off, and I see the bearings, but I can't seem to get them off. Not sure if these need to come off first?
I found this: DIY M62 rebuilding & reversing nose drive w/ pics - Eaton Inside
But I cannot figure out how he pried those rotors out of the casing at all.
Im in Ontario.
I'm thinking it's almost worth it to just buy a used M62...
Any ideas on how to get the metal out?
I tried reversing the rotors, but the pulley hub just spins on the snub, it's that jammed in there.
z28addiction
Sep 28, 2015 12:03 AM
