Major lag
Old Aug 29, 2010 | 02:04 AM
goldchain69's Avatar
Major lag
Lately I have been experiencing some major lag when I take off or shift. When I leave from a stop sign driving normal it feels like the car doesn't want move for a second or two then kinda starts picking up. I can take off in 1st about 1/4 throttle and at about 2k rpm I go wot and it starts to pick up but never feels like it is at full power all the way to redline. Also when I do a wot run it feels like it stutters throughout the gear in every gear. At first I thought it was the spark plugs but I changed them an still the same problem. I have a 2.8 pulley 60lb injectors, dual pass, cx heat exchanger, injen intake, catless dp and I have a stage two tune from Ottp. I have no Idea what it could be. I occasionally have about 15-20 min where it feels normal and once in a while it will pull a wot run like it should but 95% of the time it is really laggy and doesn't feel like full power all the way to redline. Oh and when it is laggy I hit 19-20 psi on my boost guage and when it is running normal it is just above 15 psi.
Old Aug 29, 2010 | 04:15 AM
Omega1x's Avatar
Clogged cat or bad o2?
NVM, just noticed the catless part.
Old Aug 29, 2010 | 04:18 AM
Do you think I could be that my u2 is going bad?? I do know that I am running rich if that helps narrow down the possible problems, idk if it coul b that I am running rich I never thought about it since I have been on this tune for a year
Old Aug 29, 2010 | 12:45 PM
Soulflyz's Avatar
I am having a similar issue...
when i took my car in i have a leak at the bolts of mt DP and exaust that i am loosing power from...
maybe check that?
Old Aug 29, 2010 | 03:10 PM
mrbelvedere's Avatar
check your exhaust lash adjusters i had 2 of them go bad and caused the exact same problem high boost with a case of slowness
bigdogstokes16
Oct 8, 2015 10:28 PM
dasoftest
Sep 29, 2015 02:14 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
TylerJHowell
Sep 21, 2015 06:47 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
