Maybe Blown Up?
Old Oct 20, 2008 | 05:46 PM
Armyguy151's Avatar
Unhappy Maybe Blown Up?
Well I was gettin into the car real good and then all of a sudden the car just lost power...I pulled over and the car was smokin, so i poped the hood and needless to say the dip stick had poped out and oil was everywhere...I took the oil cap off and smoke was comming out but then again it was about 50 degress outside and i just got done racing...The car starts but the CEL comes on and it runs like crap? Any suggestions... I checked the the coolent and it was fine no bubbles....so who knows
Old Oct 20, 2008 | 05:54 PM
Tomtwtwtw's Avatar
Fill her back up with oil...possible that you just blew the stick and lost your oil and nothing else. Excessive crankcase pressure can pop it right out.
Old Oct 20, 2008 | 05:56 PM
umrdyldo's Avatar
running like crap is a bad sign, might mean it is blown. Don't drive it around any if possible.
Check oil level, refill
If that doesn't fix it then good luck
Old Oct 20, 2008 | 05:57 PM
Maxim_X's Avatar
A quick check could be a flashlight down the plug holes and look for peices?!?!
Old Oct 20, 2008 | 06:02 PM
WSFrazier's Avatar
Um, compression check people?
/sigh...
Old Oct 20, 2008 | 06:06 PM
suprchged's Avatar
yea i think a refill of oil is not going to help, compression check would be the first step if i were you.
Old Oct 20, 2008 | 06:07 PM
JDMjunkie's Avatar
A guy on a local forum had the same situation happen to him. Cylinder #4 leaned out, caused excessive crankcase pressure and blew the dipstick out with all the oil.
Did the engine shut down on it's own? If so it's most likely seized. Get it up on a lift or jack stands and try to turn the engine over by hand. GL with your findings...hopefully it's nothing major.
Old Oct 20, 2008 | 06:09 PM
Armyguy151's Avatar
well it runs but when i had to drive it home everytime i pushed the clutch in the car would die...i done a compression test on it a couple of days ago before this happened and it was #1 was 200 #2 was 185 #3 was 180 and # 4 was 200
Old Oct 20, 2008 | 06:11 PM
liu's Avatar
liu
Somehow I think a compression test of before the engine broke is a mostly invalid point, just means everything was fine... before it broke...
Old Oct 20, 2008 | 06:43 PM
-Jayson-'s Avatar
blowing the dipstick out means that pressure got below the pistons, if that happened you more than likely blew the piston/piston rings.
Old Oct 20, 2008 | 06:46 PM
SCcobaltSS's Avatar
^The dipstick popping doesnt always mean blown, mine did that and it was the intake mani gasket. Compression Test it!
Old Oct 20, 2008 | 07:47 PM
Armyguy151's Avatar
well what is a good compression for these cars
Old Oct 20, 2008 | 09:33 PM
JDMjunkie's Avatar
each cylinder should be within 15% of each other.
Old Oct 20, 2008 | 09:42 PM
SSdan's Avatar
Not true. Mine were #1 150 #2,3,4 180
30 psi difference is not 15%
Old Oct 20, 2008 | 10:34 PM
JDMjunkie's Avatar
yes true, you have low compression in cylinder #1
do the test again..except this time put a little bit of oil in cylinder #1...if compression increases a bit you have bad rings..if it doesnt, it could be a burnt valve, hole in the piston, headgasket etc.
:edit:
usually if it's a bad headgasket..2 cylinders next to each other will have low compression.
Old Oct 20, 2008 | 10:37 PM
theneelster's Avatar
Let me be psychic...you blew through the crown on your 2nd piston.
Old Oct 20, 2008 | 10:38 PM
Supercharged06's Avatar
hmm it seems like these cars are blowing up every otherday, im seriously thinking about going back to stock and maybe trading for a new car
good luck with your car tho hopefully its just a headgasket or something small
Old Oct 20, 2008 | 10:45 PM
Greased's Avatar
sorry, gotta say it. ITS ALL ABOUT THE TUNE. if ya gots a good tune, your fine!
Old Oct 20, 2008 | 10:46 PM
More or less it's using pulleys smaller than 2.8". That seems to be common. You'd figure the s/c would go first not rings but...boost does that.
Old Oct 20, 2008 | 10:47 PM
i know it all about the tune. my car is still on the stock pully and i have a custom tune by 06blackg85ss(paul) and i know hes one of the best at tuneing. but it just seems like theres another one blowing up everyday.
Old Oct 20, 2008 | 10:49 PM
pimpnwink's Avatar
drain the oil if you see metal you are fuxored. But a compression test will tell you more and i seriously hope you did not drive the car without refilling the oil.
Old Oct 20, 2008 | 10:51 PM
an0malous's Avatar
what people do with their right foot blows more engines than tunes IMO.
if any of you saw what an EGT gauge, and IAT2s do after a few back to back runs, or *rolleyes* top speed runs, your eyes would boggle.
Old Oct 20, 2008 | 10:52 PM
JPizzle's Avatar
Is this only on supercharged Cobalts, or any vehicle in general?
Old Oct 20, 2008 | 11:01 PM
It's somewhat harder to blow through piston rings on a naturally aspirated engine though it's still possible...likely if you **** with the timing without knowing what you're doing. Mainly, it's the boost that blows through piston rings (and possibly crowns/domes) because the pressure is more than the rings can handle so the pressure builds and the rings (mainly the first and (sometimes) second ring) lose they're seal and that's when it's time for a new piston/rings/pins but not likely a new rod.
Old Oct 20, 2008 | 11:57 PM
Armyguy151's Avatar
yeah i put oil back in it before i drove home...i got the next few days off so im gonna mess with it and see what i can find out...i will keep post to let everyone know what happend
