Maybe an Issue...help
okay, a few weeks ago, with the help of a member on this board, I installed a 2.9 pulley, put 42# injectors on, and flashed to a new tune ( similar to stage 2, but better ). At first, I didn't notice it, but now, when I go, its more jumpy..like its having a hard time accelerating, and it smells an awful lot like oil is burning.
I've been on this board awhile, although I'm not a big poster, I pretty much get on here everyday and read. So...I've seen something like this on here, and it makes me think, is it the cat? Is it time for the new exhaust...I don't know. Anyone have a clue as to why its doing this, or what I should do?
Thanks in advance
Thanks in advance
yeah, I checked under the hood for the dipstick, since I was thinking, hey, that might be it...but it wasn't. So, you guys think I should do a compression and leak down test huh...
How was the leak down test done again?
Hear it in the exhaust = Exhaust valve
Hear it in intake = intake valve
Crankcase hissing = rings leaking
Thanks in advance
Thanks in advance
what octane is the gas your using..?
91...its all they have in oklahoma. A buddy of mine on base is running the same setup and I dont think he's having any problems...although he's got a full exhaust, and an intake.
Pskyosteve sent me the tune, and we reviewed it before uploading it on my pcm...so...I dunno. Seems good to me.
The only difference, and it may be a bigger prob. than I thought...is I'm still running the stock belt. Only because we can't get the wheel off yet due to the fact when I bought the car from the dealer, they forgot to include the wheel lock ( I bought it used - I believe previous owner still has it )....so, how bad is it that I'm still running the stock belt with a 2.9 pulley, the 42# injectors, and this tune?
I would say the problem would be more dealing with your 91 octane and the 2.9". You should probably run a step colder plug, or get some of the timing cut from the tune.
Edit:
