meth
Old Aug 15, 2009 | 11:14 AM
crazywhiteboy89's Avatar
meth
how hard is it to install who has the best price
Old Aug 15, 2009 | 11:25 AM
lsjwannabe's Avatar
Scale of 1-10 its about a 5 depending on the kit you choose and how much you like wiring
For the best price see me
Old Aug 15, 2009 | 09:27 PM
qwikredline's Avatar
agreed. I just did a reinstall with the meth and main feed wire in a loom through the interior. Its a sweet rewire, (before i just ran under the car) but it is a PITA and my fingers are sore like hell stuffing the wire and meth hose into the loom. Next time I will figure an easier way to stuff it. And then taking out the interior etc etc...what a lot of work... But OTT's stuff is excellent that devils own is good parts...
Old Aug 15, 2009 | 09:31 PM
smthomas556's Avatar
devils own. I ran the lines with the fuel rails under the car.
Old Aug 15, 2009 | 09:35 PM
EXsoccer1921's Avatar
its not that hard to install really, just depends on if you're good with well.....installing things hahah. i've been doin stuff like this for a while so it wasn't too bad. prices of kits depends on what you get
Old Aug 15, 2009 | 09:48 PM
06_SIC_SS's Avatar
ima be installin mine in the upcoming days here.. prolly next saturday.. maybe ill make up a little write up for u.. i got the devils own base kit from OTT
Old Aug 16, 2009 | 01:32 PM
ok cool if some one can help with a how to that be awsome and thanks for the help
Old Aug 16, 2009 | 02:02 PM
Crawfish7162's Avatar
I am going to go with 2.7 pully, full 3" exhaust, and all the little things to go with it. How much would meth help me?
Old Aug 16, 2009 | 03:18 PM
depends on what you want, cooling? or a little more timing? i sacraficed a little bit of cooling so i can run 25*. it also depends on what nozzle size you get. if you run only a 3gph, you can run a mix with a higher water content. but the higher you start going, the less water you're going to want to run. like, in my mix. i'm running a 90/10 methanol/water @10gph. the reason for only 10% water is because its enough to cool it down just enough to not knock, while being able to run the 25*BTDC and not have the spark blow out.
Old Aug 16, 2009 | 03:19 PM
Old Aug 16, 2009 | 03:21 PM
Old Aug 17, 2009 | 04:15 PM
tripple post
Old Aug 17, 2009 | 04:31 PM
Snakes709's Avatar
imo i think u are going to much meth...im using a 7gph nozzle, 75/25 mix and im at 25* timing...after 3 pulls on the highway i was at 149* IAT2 with 27*C weather. No knock. You could add more water to help lower your IAT2 and still have 25* timing....like i said thats my opinion...not saying what u r doing is wrong or not working.
Edit: Scratch that if u r on m62...cant remember if u have it or tvs..lol.
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
