Meth before throttle body????
Old Jun 29, 2009 | 07:27 PM
ajm5036's Avatar
So I have a Devils Own progressive meth kit, and I just recently bought the part that allows you to tap the coupler before the throttle body because I am now running a TVS and the throttle body spacer doesn't fit.
Now that being said, are there any negative to running meth before the throttle body? Will this mess up my throttle body or my TVS?
I'm running a 50/50 mix and I'm debating whether or not to pay extra and have the intake manifold tapped for meth with a check valve, or if its just as good to just tap it at the intake coupler before the throttle body.
Any thoughts? Anyone have some insight on this?
How is Area running his? ANyone???
Old Jun 29, 2009 | 08:12 PM
Maxim_X's Avatar
Most methanol injection companies recommend pre-throttle body injection.
Old Jun 29, 2009 | 08:45 PM
Snakes709's Avatar
i have the devils own meth kit as well and i bought the wrong spacer so i just drilled a hole in my intake. Runs fine. My TVS is on its way so when i change them i can see what the inside of everything looks like.
Old Jun 29, 2009 | 08:55 PM
qwikredline's Avatar
if meth drips into your maf its gone. not a bad with a 'balt as it is with a rl.
Old Jun 29, 2009 | 09:07 PM
ajm5036's Avatar
So does everyone think that you should use meth pre-throttle body or post?
Old Jun 29, 2009 | 09:08 PM
ajm5036's Avatar
So does everyone think pre-throttle body or post?
Old Jun 29, 2009 | 09:10 PM
Spectral's Avatar
mines drilled before.
Old Jun 29, 2009 | 09:11 PM
ColeJJones's Avatar
Bannned
i have done both... either way man
Old Jun 29, 2009 | 09:12 PM
Gixxerboy02's Avatar
Mine is pre throttle body
Old Jun 29, 2009 | 09:30 PM
TRANSAM197781's Avatar
not to thread jack but which nozel do you use to tap it into the coupler also thinking of going pre tb
Old Jun 29, 2009 | 09:34 PM
ajm5036's Avatar
Has this ever happened to anyone? And how would this happen?
Also any other opinions on pre or post throttle body? What are the up and down sides?
Go on Devils Own injection site its on there....um.... here
http://www.alcohol-injection.com/wat...apter-271.html
Old Jun 29, 2009 | 09:37 PM
sweet thanks for the info
Old Jun 29, 2009 | 09:44 PM
yes; most systems put the check valve by the pump. That leaves fluid in the line. depending in install the fluid left in the line could drip (siphon doncha know) into the inlet tube. The RL has a 90 degree drop to the MAF the 'Balt has a slope down and then up to the MAF so its unlikely tohappen, but smart guys would still put the check valve right next to the nozzle, and use an aquamist sensor to indicate that the nozzle is indeed spraying.
I prefer the TB spacer, but have an RL. OUr installs on 'balts put it in the tube before the TB with the check valve by the nozzle...theoretically, spraying before the TB is best. Thats all I know other than this: meth in this hot weather is worth a lot even tho' I run 94 octane 10%ethanol gas, with a tune that can handle no meth....a solid robust tune from ....area47 St.L/Mo....
Old Jun 29, 2009 | 10:05 PM
ajm5036's Avatar
Could you give me a link to this aqua mist sensor? Where do I get one, how much is it, and what does it do?
Also what do you think is the best check valve to buy? I have devils own progressive kit.
Old Jun 29, 2009 | 10:37 PM
PM area 47 the aquamist dealer is in StL. Devils own got it all its prolly the best kit, at the best ptrice, so just plumb the check valve at the nozzle...get the in trunk tank imho its the best packages the best lasts the longest....
Old Jun 30, 2009 | 08:24 AM
lol now that means your deffinition of best lasting the longest and maybe my deffinition of snow performance being the best and lasting the longest is irrelevant since its only an opinion, if you had facts THEN it would be relevant to the statement you made. not being a dick just sayin
Im going to be running mine after the TB also to OP
Last edited by 07MetallicSC; Jun 30, 2009 at 08:24 AM. Reason: Automerged Doublepost
Old Jun 30, 2009 | 09:03 AM
not being a dick I have a meth install I purchased from Hawlyns 711 and use every day. Have you installed it? I purchased Devils Own conponenets to update Hawlyns's set up, I dont know why he sold it. I will point out that I found that Devils Own provide parts to some of the other meth kit sellers; for example my experience has been that the Devils Own nozzles are superior to the other vendors.
Aquamist stuff is very good not cheap I have not seen anyone else use their stuff on these forums, and as you probably know, meth injection has been popular long before the Cobalt SS/SC came out in fact, 1960-61 GM ran oem water injection from the wwaf bottle for a turbo application.
Old Jun 30, 2009 | 12:22 PM
im not saying one is better than the other as it doesnt matter to me as long as it works. im just saying that his opinion on whats best doesnt necessarily mean it is. thats all.
Old Jun 30, 2009 | 12:58 PM
Area47's Avatar
Rent me! per hour
not in stl here
kc actually.
Old Jun 30, 2009 | 01:04 PM
ajm5036's Avatar
Area can I get your thoughts on all this? Fell free to just ramble on what you think.
Oh and I'm still looking for the aquamist sensor....does anyone know the part number?? Its suppose to check for flow.
Old Jun 30, 2009 | 01:15 PM
Area47's Avatar
Rent me! per hour
you wanting a check valve, or a flow sensor?
Old Jun 30, 2009 | 01:16 PM
ajm5036's Avatar
A flow sensor. But I have heard devils own check valves aren't very good so I would take one of them too.
Old Jun 30, 2009 | 01:24 PM
Area47's Avatar
Rent me! per hour
the flow sensor is just that. it doesn't have the properties of a check valve.
Old Jun 30, 2009 | 01:25 PM
383_Stroker's Avatar
http://www.coolingmist.com/pagedispl...ey=controllers
Old Jun 30, 2009 | 01:26 PM
freakta's Avatar
hmmm a flow sensor. i would love one of those. hell id love 4 of those. are they expensive?
