Meth fail safe???
Old Jul 1, 2009 | 12:35 PM
ajm5036's Avatar
Meth fail safe???
Does anyone have a fail safe set up on their methanol injection set up? I want some sort of insurance when I am running meth. Is anyone using one? Or does anyone know one that would work with devils own progressive meth?
http://www.snowperformance.net/product.php?pk=13
http://www.coolingmist.com/newspage....artcontroller2
Also how could I retard timing? If I run meth I plan on advancing the ignition timing... so does anyone know how you could inhibit the timing in some way?
Old Jul 1, 2009 | 12:58 PM
Zach06CobaltSC's Avatar
If you have an interceptor you don't have much to worry about. Also setup a LED light somewhere on the a pillar so that when your running low on meth it will light up .
Old Jul 1, 2009 | 01:13 PM
ajm5036's Avatar
I do have an interceptor. I usually just watch ait2 and knock retard. You think thats all I need?
Old Jul 1, 2009 | 02:06 PM
Cefaln452's Avatar
hm .
Old Jul 1, 2009 | 02:09 PM
ls1fbody's Avatar
Haz l33t wheelz.
AEM does.
http://www.allecotec.com/index.php?c...c996202ba9c5c4
WHY YOU WANT ONE
AEM's Water / Methanol Injection Kit reduces air inlet temperatures and exhaust-gas temperatures, which allows you to increase boost pressure and advance timing without having to run higher-octane fuel. It's like getting to run 100+ octane gas for the price of Premium!
WHY YOU WANT OURS
AEM's Water / Methanol Injection Kit includes all the features necessary to do water/methanol injection right. No hidden costs or optional components are required. Unlike other popular kits on the market, we include a one- or five-gallon tank with a fluid level sensor standard. Also, because we think engine protection is a requirement, not an option, we include our Boost Safe output in every controller we design. This feature allows you to retard timing or reduce boost if the system runs out of fluid or detects an error. With the AEM Water / Methanol Injection Kit, you get all the best features in one low priced kit.
HOW IT WORKS
Once installed, the Water / Methanol Injection Kit uses a boost-dependent, variable-flow progressive controller to determine the amount of water / methanol mixture (up to 50%) to feed into the inlet stream from the included one- or five-gallon reservoir. The controller commands a progressive 150-PSI pump that delivers the mixture, and flow adjustments at the inlet are made via three included jets designed to match most engine power requirements. The result is significant horsepower gains using pump gas-at about half the cost of Racing Fuel.
OTHER COOL STUFF
You don't have to worry whether AEM has your application because the Water / Methanol Injection Kit is designed to be universal for practically any vehicle. It includes everything you need to adapt it to your steed. Critical safety features are integrated into the system to virtually eliminate any chance of failure, including an integral fluid level sensor in the reservoir, a dash light to warn of low fluid level or error codes (including short circuits, battery voltage and more), and an additional output to either decrease ignition timing or boost if the system detects low fluid levels or a system error.
Old Jul 1, 2009 | 02:13 PM
Interceptor and a good tune is all you will need, but to be even more safe just grab the tank level fluid light and set it up in your a pillar. Then every now and then take a look at your outside meth nozzle and make sure its clean and still misting properly.
Old Jul 1, 2009 | 02:17 PM
rnjmur's Avatar
If you have access to HPTuners you can always adjust the IAT2 boost control so that if the tempurature reaches a certain point, for example 160F, then boost is reduced to 50%.
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Rduncanss06
Sep 27, 2015 11:17 PM
Sep 27, 2015 08:53 PM
