meth help
Old Aug 27, 2010 | 10:38 PM
advise's Avatar
meth help
so i got a meth kit here on the forums and its an ais stage 1 trunk mount and i was just wondering how do i adjust the activation pressure setting on the pressure switch
Old Aug 28, 2010 | 12:18 AM
iboost's Avatar
my aem kit has a couple of potentiometers that you turn to set max and min pressure
Old Aug 28, 2010 | 02:39 AM
advise's Avatar
bump for help
Old Aug 28, 2010 | 02:44 AM
06arrivalSC's Avatar
I just got the AIS fender mount kit, should be relatively similar. on mine there is a little hole for an allen wrench near the area where the vacuum line comes in for the boost activation switch, find the right size allen wrench and you can turn the boost activation switch for the meth to come in at a lower or higher boost level. the instructions will tell you which way to turn the switch depending on if you want the meth to spray at a lower boost level or a higher boost level.
Old Aug 28, 2010 | 02:46 AM
Maupin SS/SC's Avatar
i bought it ad sold it to him i dont know much about it so help him. it was exsoccers kit hope he sees this
Old Aug 28, 2010 | 02:47 AM
advise's Avatar
ya i saw that i have no instruction because i got it used
do u adjust it and guess or is their any sure way to tell what psi its set to
i sent him a pm Maupin
Old Aug 28, 2010 | 02:49 AM
ok ya he should know because i literally am clueless about meth and all that jazz sorry. im glad u got it bc i forgot a return label. GOOD thing it was disguised as a printer
Old Aug 28, 2010 | 02:57 AM
advise's Avatar
any idea who makes the spacer
Old Aug 28, 2010 | 03:01 AM
Im not at home, but once im home on monday afternoon i can scan that section of the instructions for you, since the actual switch is kind of one big guess, this is how we tested to see what boost level the meth was spraying; i can take pics of this for you sunday if youd like because me and my buddy are tweaking the setup for the meth to start spraying later. Anyways, on my setup, we took the vacuum line coming from the intake manifold and spliced it, put in t-fitting and ran a vacuum line from this t-fitting to the boost activation switch. So to test when the meth starts spraying we took a mechanical boost gauge (we have randomly built up a stash of random car parts through the past 3 years, if you dont have a mechanical boost gauge theyre like $40 at an autozone and it will come in handy for this and weve used it for several other things in the past year) anyways, we took a mechanical boost gauge and hooked a vacuum line from the gauge and ran it to a t-fitting. we took the vacuum line running to the boost activation switch and hooked it up to the same t-fitting, on the 3rd nipple of this t-fitting we put a vacuum line that wasnt hooked up to anything. we then took his air compressor, bled the pressure in the tank so it wouldnt be a shitload of pressure coming out of the "hose" (not sure the technical name for this, but it has a little handle on it you push to let air out of the nipple, the harder you push the more air that comes out) we took the nipple on the air compressor hose and put it in the vacuum line not hooked up to anything. we then unhooked nylon hose running to the nozzle and just set it in a towel. now take the hose/nipple running into the vacuum line and slowly push the handle to push air through the vacuum line and keep an eye on the boost gauge to see how much pressure there is in the line; slowly push the handle, keeping an eye on the boost gauge and then when the meth sprays you will have a very accurate idea of what boost level the meth is spraying at. tweak with the boost activation switch if you need to and keep repeating this process until the meth is spraying at the boost level you want.
If you need more explanation on this i have no problem reexplaining or making you a diagram in 'paint' until i can take pics
spacer...? are you talking about a throttle body spacer tapped/threaded for a meth nozzle?
Old Aug 28, 2010 | 03:08 AM
i think its ottp the fitting is perfect i wouldnt move it and it goes to the front aiming up
Old Aug 28, 2010 | 03:17 AM
advise's Avatar
ya if you could do paint and take pics that would be great
o im just askin Maupin SS/SC what type of spacer he sold me
Old Aug 28, 2010 | 03:22 AM
That works, or you could do what i did and save the $30 or so that it costs for the throttle body spacer and drill/tap a hole in your intake for the nozzle, both work though, its just up to you as to whether you want to put a whole in your intake in case you want to do something different later, sell it, etc
Old Aug 28, 2010 | 03:27 AM
he has a tb spacer ready to go lol its a full kit
Old Aug 28, 2010 | 03:32 AM
Well then hell yea lol
Old Aug 28, 2010 | 04:23 AM
PM sent with a diagram to you 'advise'
Old Aug 28, 2010 | 11:44 AM
advise's Avatar
got the pm now i understand but their isnt a way to set it like every 1/8 turn is a psi
Old Aug 28, 2010 | 01:17 PM
Im not 100% sure, that sounds about right but i couldnt say for sure, ill check that tomorrow when we mess with my setup
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
