Meth Hook up, Help!
Old Aug 8, 2011 | 11:56 AM
TiE2000's Avatar
Meth Hook up, Help!
Ok, I just got done installing my devils own meth kit... got everything plumbed and got the nozzle drilled into my CAI. But the problem is I don't know what MAF wire to tap into for the correct voltage so I spray only when I boost.
Does anyone who is running meth on an LSJ know what wire to tap into?
Thanks for the help guys!
Old Aug 8, 2011 | 04:31 PM
TiE2000's Avatar
Bumb... really no one knows?
Old Aug 8, 2011 | 04:36 PM
zrated89's Avatar
you are obviously running a progressive controller than right? most of us lsj guys run the hobbs switch/ boost switch setup. on a blower there is no need to have a progressive controller. the kit should have come with directions contact devils own
Old Aug 8, 2011 | 04:39 PM
TiE2000's Avatar
Good to know, didn't know a controller was not needed for the LSJ, Looks like I will need to buy the switch, as this kit was purchased from a LNF owner. I do have the instructions for the controller but no switch.
I will contact Devils own.
Thanks.
Old Aug 8, 2011 | 04:45 PM
IonNinja's Avatar
It tells you to tap the MAF to get a boost reading?
Old Aug 8, 2011 | 04:50 PM
06cobalt racer's Avatar
think he meant map?
Old Aug 8, 2011 | 04:55 PM
TiE2000's Avatar
yes sorry it is on the MAP sensor on top of the SC. Currenlty it's hooked up to the orange wire.
As this kit came from an LNF, they connect to the MAF sensor on their CAI. We tried that... but it was spraying even at idle. So then we readjusted to the MAP ontop of the SC, and we get no spray at all.
Old Aug 10, 2011 | 09:00 PM
paddock's Avatar
The only thing I can tell ya is that with the progressive controller, you wire into the plug next to the supercharger snout..
I can't remember which wire.. and it's dark outside..
If you need more info., pm me, and I'll take pics tomorrow..
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
