Meth Injection????
Old Oct 4, 2012 | 12:10 PM
Squidman040's Avatar
Meth Injection????
i saw a few kits for installing meth injection, its safe and lowers air temp, but is it worth it and is it cheap to refill or even worth bothering to look into? who can help me? thanks
Old Oct 4, 2012 | 12:20 PM
Bluelightning's Avatar
Got Bewst?
Absolutely it's worth it. Cooler intake temps and allows you to run a more agressive tune. A lot of people on here get brainwashed and scared because if your meth fails your motor can go down. There's always the possibility of it but if you take proper safety precautions like hooking in a pressure switch with an led light so you know your meth is on and setting your interceptor if you have one to light up when you get knock, watch your stuff and you will be fine. I've run meth in my car almost since day one and had no issues. Bang for your buck is devilsown stage 1 kit. 5 gallons of meth costs me $25 and I mix it 50/50 with distilled water. It's super cheap to run. Just make sure you get tuned for it.
Old Oct 4, 2012 | 09:10 PM
bluebalt07's Avatar
It's a great mod. As bluelightning said, as long as you maintain the system, you shouldn't have any problems. Just check the pump and nozzle filter often to make sure everything is ok. Meth itself is pretty cheap depending on what you run. A lot of people run windshield washer fluid with some Heet added to create a 50/50 mixture. I don't care for that idea though simply because of the dyes and detergents in the washer fluid, so I buy straight methanol and mix 50/50 with distilled water like bluelightning. You can get 100% methanol by using bottles of Heet or buying it by the gallon. Speed shops and race tracks should sell it and its fairly cheap. Costs me $2.95 a gallon and then like $1 for the water.
Old Oct 8, 2012 | 07:11 AM
MyOtherSS's Avatar
If you aren't lazy about it meth is easy to maintain. Like the others said find a way to monitor your system (light or interceptor) and you'll be fine.
Old Oct 20, 2012 | 06:28 PM
briank6102's Avatar
I have a methanol question.. How often do you have to fill the methanol tank? And is it better to buy the pre-mixed methanol/water or buy straight methanol and mix it yourself?
Old Oct 20, 2012 | 06:30 PM
briank6102's Avatar
Oh.. And is the aem methanol failsafe a good purchase or would it be better to just by a gauge to monitor the flow of meth?
Old Oct 20, 2012 | 06:33 PM
bluebalt07's Avatar
It's better to buy methanol and mix it yourself. Much cheaper and won't have dyes and other crap like that. Refilling it depends on how you drive and nozzle size. It only turns on when you are in high boost at WOT and its only on for those few seconds so a tank will last awhile
Old Oct 20, 2012 | 06:54 PM
briank6102's Avatar
Well doesn't the progressive injection spray accordingly to boost? I'm a newb to all of this. I'm doing research before I install this.. I currently have 3"dp, vibrant headers, phenolic spacer, dual pass plate, 60's, 2.6, WickedSS hptuned..
Old Oct 20, 2012 | 06:57 PM
briank6102's Avatar
Sorry, what I'm trying to ask is does the progressive water/methanol kit spray as soon as boost is achieved??
Old Oct 20, 2012 | 07:06 PM
TStone's Avatar
Tuned by Tom? Where exactly are you from?
Old Oct 20, 2012 | 07:30 PM
briank6102's Avatar
Yeah Tom tuned me.. I drove down to him and stayed the weekend.. I'm from St.Louis mo.. It's about a 5 hour drive.. I'm actually talking to him about tuning in my meth kit and cams..
Old Oct 20, 2012 | 07:33 PM
Pleass's Avatar
Whos tom
Old Oct 20, 2012 | 07:35 PM
briank6102's Avatar
Originally Posted by Pleass
Whos tom
WickedSS.. Tom does tuning in the Ohio and surrounding areas.. He's tuned 200+ ecos
Old Oct 20, 2012 | 07:38 PM
briank6102's Avatar
So back to my original question.. I'm not too familiar with meth injection but understand the concept.. What's the difference between the progressive meth injection and a standard kit?
Old Oct 20, 2012 | 07:41 PM
TStone's Avatar
Progressive is controlled by boost like starts spraying at 10psi and full spray at 20psi.. Basic is just, when you hit xpsi it sprays full blast
Old Oct 20, 2012 | 07:44 PM
briank6102's Avatar
Can you adjust the pressure it activates on them? Which is better?
Old Oct 20, 2012 | 07:45 PM
TStone's Avatar
I prefer progressive. It mostly just depends on what your tuner wants to do. Talk to Tom. Even though he's anti meth baha. && yes you can, in both kits.
Old Oct 20, 2012 | 07:50 PM
briank6102's Avatar
Yeah lol anti meth and anti cams!! He told me yesterday that cams weren't beneficial when he was doing his build so he don't know about them.. He's tried to talk me out of meth but with all the new stuff and failsafe features from what I gather as long as your not a idiot and keep an eye out and do the required maintenance then there's no harm at all..
Old Oct 20, 2012 | 07:55 PM
briank6102's Avatar
Tom just said "Tyler's a big fan of mine! Lol" I'm texting him too
Old Oct 20, 2012 | 07:58 PM
TStone's Avatar
Haha Tom is a cool ass dude. Great tuner for sure. He just had E locally to him so he hates meth haha. But he can handle it.
Old Oct 20, 2012 | 08:12 PM
briank6102's Avatar
Yeah I like Tom a lot and he knows his **** for sure.. I've been down to his apartment 2x's now for tuning and parts off his cobalt.. I installed his new stereo in the speed3 for him the last time.. What mods do you have? LSJ or LNF?
Old Oct 20, 2012 | 09:57 PM
TStone's Avatar
2.6/Tvs, all bolt ones, & meth
Old Oct 21, 2012 | 01:24 AM
MyOtherSS's Avatar
How exactly did you run your led? T into the meth line to a pressure switch then to a light?
Old Oct 21, 2012 | 08:40 AM
TStone's Avatar
It wires into the controller
Old Oct 21, 2012 | 09:12 AM
MyOtherSS's Avatar
I'm not progressive and I don't think Bluelightning is either.
