Meth kit?
Old Feb 18, 2013 | 10:35 PM
brentp's Avatar
Meth kit?
Really thinking about running the zzp meth kit but i have a few questions first. Does it require any type of tune I haven't seen anything so I'm guessing it doesn't. Also second I've read that it will create more boost but I'm already pushing 16 psi and I know the stock m62 isn't good over 16 so will it cause belt slippage at all if its even true ? And third what kind of hp increase and iat temp drop will it create? Thanks
Old Feb 18, 2013 | 10:55 PM
Bluelightning's Avatar
Got Bewst?
ZZP doesn't make a meth kit it's Snow Performance. Yes you will need a retune. Yes you can go further than 16 psi on an M62 without issue. No it won't cause belt slip. Hp at IAT's vary on set up.
Old Feb 18, 2013 | 11:31 PM
mrbelvedere's Avatar
use the ******* search button there is plethora of meth information on here
Old Feb 18, 2013 | 11:47 PM
Got Bewst?
Knew that was comin
Old Feb 18, 2013 | 11:50 PM
coolbalt1's Avatar
Would you say I have a plethora of pińatas?
Old Feb 18, 2013 | 11:59 PM
Are you calling me a sissy?
Old Feb 19, 2013 | 12:15 AM
coolbalt1's Avatar
Can I have ur watch when u are dead?
Old Feb 19, 2013 | 07:23 AM
brentp's Avatar
Did use the search button but anytime METH is in a word which is a lot like close to 1200 post of stuff I don't need.. I would rather just ask a question
Old Feb 19, 2013 | 07:29 AM
BlackARCA06's Avatar
Yea search button on here blows i always go to google type in your question then add cobalt ss after it and all the threads should pop up or anything related to it.
Old Feb 19, 2013 | 08:04 AM
TStone's Avatar
It's snow performance.
Yes you will need a tune.
Methanol won't create more boost. I hope you're on a tune with that 16psi. Also, the m62 is good past 16psi.
Adding methanol will not cause the belt slip. Dropping a pulley size will cause the belt slip.
Hp all depends on the tune.
Iat2 drop depends on a lot of things such as pulley size, nozzle size, what you're revving too, etc.
Thanks
Welcome
Ps.. Use the search bar and only look at threads in the LSJ section relating to methanol & it'll narrow your results & give you the information you need.
Old Feb 19, 2013 | 09:30 AM
Got Bewst?
Spraying water/meth through the blower will create more boost.
Old Feb 19, 2013 | 09:32 AM
07ssBOOST's Avatar
Oooooo mr B is gonna get you boy...
Old Feb 19, 2013 | 09:38 AM
TStone's Avatar
Methanol willl help you lose less boost but it won't create more
^^^^^ mrb's words
Others will say it creates boost.
Colder air creates a denser charge which in turn makes more restriction.
Methanol also closes up tolerances in the sc, making it more efficient. Less air leakage more cfm output
^^^ words of 100%METH
Old Feb 19, 2013 | 10:02 AM
brentp's Avatar
Thanks for the help guys I'm going to put the meth kit on and have big 3 racing tune it for me I live 25 min away is there a way to have the snow performance kit all hooked up but not running so I can drive it to get it tuned?
Old Feb 19, 2013 | 10:04 AM
07ssBOOST's Avatar
I would imagine hook everything up but not wire the pump....but anyway it shouldnt hurt your car from what ive read without a tune you just wont get full potential till it is...i may be wrong im sure someone with more knowledge will help
Old Feb 19, 2013 | 10:07 AM
06cobalt racer's Avatar
just dont go into boost
Old Feb 19, 2013 | 10:13 AM
so your a welfare modder then
Old Feb 19, 2013 | 10:16 AM
TStone's Avatar
You can have the meth completely hooked up & if you stay out of boost, you'll be fine.
If you can't drive without going wot then hook it all up except power wire. Then hook up the power wire when you go to get tuned
Old Feb 19, 2013 | 10:31 AM
07ssBOOST's Avatar
Whoa...he was nice to you....
Old Feb 19, 2013 | 10:36 AM
Got Bewst?
^^^^^ mrb's words
The tightening of the rotor tolerances is what creates the higher boost.
Old Feb 19, 2013 | 10:43 AM
TStone's Avatar
Mrb is nice to everyone. But if you ask questions that can easily be answered if you search, then he gets pissed.
Old Feb 19, 2013 | 10:47 AM
07ssBOOST's Avatar
Ive noticed! Lol in my defense the company was closed last night so that was my last resort!
Old Feb 19, 2013 | 10:49 AM
the water meth you spray into the blower keeps the blower from loosing what it makes by sealing the rotors it dosent create pressure it helps seal **** up
Old Feb 19, 2013 | 10:57 AM
brentp's Avatar
No I'm a college kid
Old Feb 19, 2013 | 10:59 AM
TStone's Avatar
I don't think that's what he meant
