Meth mix?
Meth mix?
What should I run? 90/10 or 75/25? 100/0? What do you guys think would be the ups and downs of each? I just bought a progressive meth kit with all stainless hoses. JUst trying to get some opinions.
My IAT2s are normally low. Maybe 140 max after consecutive pulls.
I should probably add more details like I am running this mix with a TVS on a 2.9 pulley with 80 lb injectors.
hmm....yea i say 75/25 would be good. The meth will help keep your timing and the water will help keep your temps low after alot of runs. Although i dont know if there is a difference between the 60lb and 80lb injectors...whether it changes things.
You put two bottles of HEET in and filled one bottle half full with water? How many cycles of this did you do?
If you have access to 100 methanol and want the most hp run at least 90/10.
Once again, it really doesnt matter at that point...i ran the TVS with 25* timing on 75/25. You dont want to go much further then 25* timing so now point going any higher on meth...all you are doing is lossing your cooling.
I agree with you not to run more then 25 degrees. Even 25 degrees you are putting a lot of extra stress on the rotating assembly. Time for more boost!
whatever my set up is at..havent dynoed yet but say im on a descent tune already...have people posted there gains yet from meth tunes..i havnt found any
nice...thanks
nice...thanks
Last edited by brownbandit9; Dec 15, 2009 at 11:28 PM. Reason: Automerged Doublepost
I went to the dyno when I first converted to E85 and was still on the stock blower.
Here were my results.
Run 1 - 2.8" on 18 degrees of timing.
Run 2 - 2.8" on 25 degrees of timing.
Run 3 - 2.7" on 25 degrees of timing.
So on a 2.8" pulley I gained 14whp and 10wtq going from 18 degrees to 25 degrees of timing if that helps.
So I have been told that buying meth from a local speed shop or a track would be really cheap. How much have you guys paid for say a 5 gallon bottle? I'm just asking because I found this web site that will ship it right to you for $52 for each 5 gallon container.
Any thoughts?
Any thoughts?
