meth questions
Old Sep 3, 2008 | 09:52 PM
stevew2405's Avatar
meth questions
i was just wondering how much does a one quart bottle last our cars i have not installed my stage 2 kit yet but i installed my meth kit and i just was wondering what was an average time frame that it lasts i have the ais stage one fender kit with the 1 quart tank
Old Sep 4, 2008 | 12:24 AM
Rippin07's Avatar
totally dependant on your driving style, the harder and more frequent heavy footing will result in running out sooner.
Old Sep 4, 2008 | 12:25 AM
Raven SS's Avatar
why are u running meth on a stock setup? or even a stg 2?
Old Sep 4, 2008 | 12:26 AM
EXsoccer1921's Avatar
lower temps silly!! haha
i was actually thinking about getting meth, h/e, dual pass w/ opt b. before i did any mods at all. how is that a bad idea?
Old Sep 4, 2008 | 12:30 AM
Raven SS's Avatar
wow..thats what meth does?????? lol...
running meth is for a cooling effect but mostly for running more octane so u can push the timing as far as possible..with only being a stg2 and not creating much heat meth isnt needed u can run a h/e and dual pass (because if u running stage 2 ur not really worried about being the fastest) and u dont benefit adding more timing much more than what a stg 2 provides so if ur maxed on timing then what is meth doing for u? waste of money IMO..now if ur running a small pulley then yes..good upgrade..but a stock car or stg2...ur just wasting money
Zach06CobaltSC's Avatar
Running methanol untuned will just make you extremely rich unless you are only spraying distilled water which will lower temps. I recommend only running a small amount of methanol if you are stock or untuned. Distilled water only will result in the best increase since you are stock.
Old Sep 4, 2008 | 06:31 PM
stevew2405's Avatar
thanks for the info i am just waiting on 2 more parts then i will have my stage 2 and dual pass with option b and my heat exchanger than i will get it tuned
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
