Meth users look here..........
Old Mar 1, 2007 | 10:08 AM
Kennyspec's Avatar
i guess this proves that water/meth will destroy the coating on the M62 rotor blades.
Old Mar 1, 2007 | 10:12 AM
Ljavy17's Avatar
ellaborate dude, how long did have it for. What kind of mixture did you have. is this your car? did you lose any boost?
Old Mar 1, 2007 | 10:15 AM
Bad06SS's Avatar
Need more details. Do you own a S/C Cobalt? As mentioned, mixture, how long, etc.
Old Mar 1, 2007 | 10:17 AM
fastSS06's Avatar
i've been running meth for about 4 months and the coating on my blades are still fine
Old Mar 1, 2007 | 10:19 AM
srt-killer's Avatar
Holy ****! Ive been running mine for about 4 months aswell. I hope mine isn't F*cked up! I will check this weekend when i port my blower.
Old Mar 1, 2007 | 10:20 AM
shabodah's Avatar
Alcohol has the same effect on regular old aluminum over time, too. Just ask any of the E95 Diesel guys in California.
Old Mar 1, 2007 | 10:23 AM
srt-killer's Avatar
I thought our 5th gen blowers had apoxy coating instead of teflon to prevent this from happening.
Old Mar 1, 2007 | 10:25 AM
SSdan's Avatar
Is this bad, will it hurt performance from the blower?
yellowcobaltss05's Avatar
this is not good news need more info too as i am about to do meth injection
Old Mar 1, 2007 | 10:28 AM
06blackg85ss's Avatar
**** I had it on for 10,000 miles and it still looks as good as new inside... were you just using washer fluid... and what s/c is that and off what car
Old Mar 1, 2007 | 10:31 AM
Ljavy17's Avatar
it says LSJ on it , However, I bet he was using washer fluid, or 100 percent meth.
Old Mar 1, 2007 | 10:35 AM
SSdan's Avatar
So is this bad?
Old Mar 1, 2007 | 10:36 AM
sounds like someone didnt mix the meth correctly or did something wrong on the install bc this is the 1st time ive heard of this. Makes me kinda wanna spray first lol
Old Mar 1, 2007 | 10:56 AM
R33P3R007's Avatar
360 L337 User
it doesnt look like it is a Gen V LSJ blower. what is it off. What mixture were you using
Old Mar 1, 2007 | 11:01 AM
spooler's Avatar
threadjack: hahaha, "meth users"
Old Mar 1, 2007 | 12:33 PM
RaineMan's Avatar
Using washer fluid? Like the soap stuff? That's gotta fvck something up...
Old Mar 1, 2007 | 12:50 PM
ReMz's Avatar
this thread is stupid w/o info.....
Old Mar 1, 2007 | 12:54 PM
glockglade's Avatar
Thank God i didn't order this yesterday I guess it is heat exchanger time
Old Mar 1, 2007 | 01:13 PM
Bad06SS's Avatar
Wow, your gullable. All the guy does is post a pic and you want to freak out? I've had the meth on my car for almost a year now (longer than this guy has been a member here) with no issues, and I spray a 70/30 PURE METHANOL mix! That pic doesn't look like our Gen V M62, the poster has a whole 67 posts-not enough to prove any trustworthiness. He gave no details or explanation either. I think that coming in here and just posting a pic without an explanation, stirring stuff up is stupid. I call BS untill a valid explanation or real proof is shown. Which is probably going to be hard to do.....
Old Mar 1, 2007 | 01:17 PM
SSdan's Avatar
Ok so once again, is this really bad?!?! Does it hurt performance?
Old Mar 1, 2007 | 01:26 PM
glockglade's Avatar
Gullable? Hmmm try more like cautious as I don't want to spend 1300 on a new blower, until we figure this nonsense out i am not buying the meth kit.
_Bad06ss_ I appreciate your opinions but if they insult other members keep it to yourslef. until i see some pics of your blower this guy is going to be the one I trust he has pictures you do not. Now granted this could be from anything but until we found out I'm assuming its true.
Old Mar 1, 2007 | 01:35 PM
Bad06SS's Avatar
When did I insult anyone? I never insulted anybody, I doubted his claims. No problem, I am getting my blower ported in a few weeks, I'll post a pic before and after the porting, and then I'll post my timeslip for you too.
You have the right to believe whoever you'd like, but there's quite a few members who have been in this community awhile that have been spraying pre-blower with no issues. Again, most of the guys I'm referring to have had a meth kit on their car longer than this guy has been here. If there were issues, we'd know by know. The GEN V M62's do not have teflon coating, they are epoxy.
I'm still not convinced that this is a picture of our blowers. However, on the OLDER generation blowers, they had teflon coating for SOUND purposes. If the coating is stripped, it makes the blower louder, but does not hurt performance.
Old Mar 1, 2007 | 01:36 PM
djt81185's Avatar
Only blower i seen that looks like that had teh bearings fail...and that was my blower. The bearings had been making noise since day one.
The other car here...Fast06ss...(he posted earlier in this thread...not rob) has 0 rotor wear...and Rob (fastss06...confusing ******* names) noted no wear on his m90 gen v or m62 gen v blowers spraying meth thru em
Old Mar 1, 2007 | 01:39 PM
R33P3R007's Avatar
360 L337 User
or you order the tag kit that sprays after the blower
Old Mar 1, 2007 | 01:41 PM
zinner's Avatar
Moderator Alumni
I have had some wear on my rotors since day one. It's on one rotor only and it's gotten a little worse with time and nitrous/fuel mixture passing through it.
Our rotors aren't Teflon coated which wears off with time, our is some epoxy compound. If you have a Teflon frying pan and use metal on it you know Teflon won't last forever.
That said, water is a universal solvent and with time will break down any substance. I would also be concerned with corrosion when using water with metal.
